Canon pixma mx360 Printer saids document in ADF and won't print
5 Suggested Answers
  • 412 Answers
SOURCE: Canon PIXMA MP140 Service error 5100
ok... you have to reset the printer --
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Hpoe this helps
Posted on Mar 09, 2009
SOURCE: My printer is a Canon
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Posted on Oct 29, 2010
SOURCE: Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Posted on Apr 15, 2011
alpug
  • 1961 Answers
SOURCE: my canon pixma MX320 reads document in ADF how do
Hello!
Please check on the ADF section if there is a jammed paper and remove it. ADF stands for Automatic Document Feeder, it is where you put the paper for faxing.
It is also better to check the paper sensor on the ADF section and see if it return back to its normal position. Open the cover of the ADF section, you will find a white plastic that click when your press down and lifted up back when release. This is the paper feed sensor. If this do not return to normal position, you will need to have it replaced by a certified printer technician.
Removing the power cord at the back and leaving it for at least 30 minutes will sometimes do the trick of removing the error on your printer.
Posted on Jun 29, 2011
Ip tool reset Canon Pixma MX360 Printer
Apr 15, 2013 | Canon Pixma MX360 Printer
Canon pixma mx410 document in adf has paper inside
The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". ..............................solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution .....................................THIS WORKS!!!!!!!! thank you
Sep 12, 2012 | Canon Pixma MX410 All-In-One Printer
Canon pixma won't install computer says something about the drivers
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Apr 17, 2012 | Canon Pixma MX360 Printer
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
a) & b):
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
My CANON PIXMA MP530 is showing the alarm, "Document in ADF."
Open the top cover of the ADF and look for a rectangular hole with a lever stuck down. That lever should only go down when a paper is placed in the feeder, and sometimes they get stuck in the down position. A bent paper clip might help you lift it gently...
Jun 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
47 people viewed this question
jasbo
jasbo
