Question about Epson STYLUS OFFICE T1100 COLOUR INKJET PRINTER
Epson T1100 printer general error
I have a general error (two flashing lights, paper and ink). Does anyone know how to fix or reset this?
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
websnail
  • 419 Answers
SOURCE: MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
Posted on Feb 17, 2009
SOURCE: epson R300 "GENERAL ERROR SEE YOUR PRINTER DOCUMENTATION FOR INFORMATION ABOUT CLEARING THE ERROR".
in my r300 epson printer general error appear . How can i remove or clear this error from my printer lcd
Posted on Apr 27, 2009
eric1121
  • 265 Answers
SOURCE: both ink and paper light are flashing alternate
Your printer needs to be reset. Flashing lights means that your waste ink pad is full when that happens printer stops working to prevent flooding of waste ink inside your printer. Google search for a resetter program for epson d68. You need to replace the waste ink pad or create a tube line to divert the waste ink out of the printer. Good luck.
Posted on Jan 13, 2010
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
What does the problem when general error occur on screen and blinking both led resume and ink
Hello sir,
This error you are having it indicates that your printer's ink pads are at the end of their service life and you have to change your printer or replace them.But you can try this first.
Turn off the printer. Open the printer cover and remove any paper or other obstructions from the paper path. Then turn the printer back on. If the error does not clear, contact your dealer.
Thank you
Apr 24, 2014 | Epson Stylus Office T1100
How to fix general error of t1100 epson printer
Apr 07, 2013 | Epson Stylus Office T1100
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Flashing alternately PRINTER EPSON STYLUS T1100
This is a standard problem often referred to as a "Service required" or "waste ink pad" problem.
You have two things that need sorting out.
1. Getting a compatible reset utility either one of the AdjProg utilities out there or the WICReset (iWIC for Intel based Mac computers). These will help with resetting the waste counter and allow the printer to be used again.
2. Checking the waste pads and, if necessary installing an external waste ink kit/tank to redirect waste ink to. This avoids the potential for any leaks when the pads overflow.
The actual utilities and kits are available, sometimes as kits or bundles so worth doing some digging on eBay or on the web in general.
Dec 15, 2012 | Epson Stylus Office T1100
General error remove foreign objects inside the printer
Getting General Error Messege delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer
Jun 08, 2011 | Computers & Internet
Epson Stylus SX100 General Error
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson R230 ink & Paper Lamp Blinking
Blinking alternately or not? If alternately, need to reset waste ink counter. SSC can fix it. But if not, it's general error. It's may be carrriage error.
Aug 02, 2009 | Epson Stylus Photo R200 InkJet Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson C48 inkjet printer flashing lights
I can tell you how to fix this if anyone is interested - report back if so.
Jan 13, 2008 | Epson Stylus C48 InkJet Printer
Epson STYLUS OFFICE T1100 COLOUR INKJET PRINTER Logo
202 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
