Question about Conair Hct420csv Hair Trimmer
How do I reassemble the two metal blades including plastic piece to insert into The Chopper Conairclipper
I disassembled the clippers to clean them, but can't remember how to get the metal blades back together I also have the plastic piece that appears to attach to the smaller blade but I don't know how they fit together correctly.
SOURCE: fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
SOURCE: Can't snap on blade for dog clippers
Not sure why they won't go back on unless the clip has collapsed in which case you would need to take a screwdriver and pop it back up. Andis and Osters are the best clippers out there however.
Posted on May 13, 2009
triloberto
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Posted on Jun 07, 2009
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
SOURCE: I can't find the manual
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Posted on Feb 28, 2011
Water will not come out top agitator on my kitcheaid dishwasher
You need to take out the bottom rack of the dishwasher and disassemble the lower spin arm and filters underneath it. You need to get right down to the chopper blade and disassemble and clean out the chopper blade assembly. Make sure there is nothing buried in the little holes. Once done and you are sure it is clean. Reassemble it all. It should work fine. Having said that.......It will happen again in a few washes until you replace the whole chopper blade assembly.
Jul 30, 2014 | KitchenAid 24 in. KUDS01FLBL Built-in...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
I have Wahl vision 180 B & M trimmer M 9858, with 3 complete parts separated:a)a 1.5" x 1.5" flattish blk plastic & metal piece with cutting 'comb' at the end; b)a 1" x 1.25" Blk & metal piece...
It is very likely that one of the plastic pieces that hold the spring mechanism broke. If you send it back (with all the pieces and clipper) to Wahl Clipper, 2900 N. Locust St., Sterling, IL 61081, they will probably fix it for you for free.
Sep 17, 2009 | Wahl Vision 180 Beard Trimmer
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Conair hc318d reassembly
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Conair Hct420csv Hair Trimmer Logo
24 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
