Related Tags:
This problem should be removed because:
Problem with Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV 32FS120
Hi...I have a Sony FD Trinitron WEGA KV 32FS120 that is very difficult to turn on. When I try to power it on the stand by timer light blinks 9 times then stops the repeat for another 9 times. Aventunally the TV does come on after repeated pushs of the power button. Can some please tell it this something that I can repair or do I need a service person...Thank you in advance...David
Solutions (14)
Best Solution
This model does not have a G board. I will post when I have this solved.
Replace D645 and D647 with 2.5A1KV diodes.PROBLEM SOLVED. Thank you Solution #5.
Just to reiterate. This solution pertains to the Sony KV-32FS120. The ZCD erroring circuit is on the A board. You can Google the web for a Service Manual. Most are pay sites, but I did manage to scare it up, no cost. The board layouts, and part numbers were most helpful.
User. "bsee" was most accurate. Added solder to all large parts in area. also resoldered some small parts. But still would not turn on. Found references to 3 users that replaced either Q605, D690, or D647 to solve problem. I replaced Q605, but problem remained. I then replaced both D690 and D647 at same time and problem solved. Not sure which one was problem.
Sony will not sell parts directly, but again just Google Sony parts to find a dealer or parts house able to sell all 3. Total price was about $15.00 not including preferrred shipping. Used a 30 watt soldering iron kit from Radio Shack that include clamp handily used on leads as a heatsink, some desolder braid, and .031 60/40 rosin core solder. Had a smaller 15 watt iron, but it didn't heat up to a usable level for desoldering. Thanks again for the advice...
Russ
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Could be Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13v (negitive).
dump the piece of cr%p.
unsolder the h-output Q502. does the b+ to hvt come up and stay on? if not then replace IC600. if so then check q502, d500, d502, d503 for shorts. if checks ok then unsolder q532 and see if it runs.
ok i got a sony board kv32FS120 where can i get the parts at so i can replace them thanks
Hi I have the same problem 9 blinks. I've tried searching for the parts on google but I can't find those parts D690 D647 Q605. can someone point me to the right direction?
Sony KV-32fs120 with 9 blinks. Resoldering only results in a temporary fix. Replace D645 and D647 with 2.5A1KV diodes.
We had a similar problem with ours. It requires the set to be unplugged for 36 hours and it is working fine.
Hp Sydney Aus.
This problem is always in the remote control circuits. The main control IC is IC001 on the M plug-in board. This is the main possibility for the failure. It may be Q605 or the other transistors on the M board, but not as likely as the IC, since you are getting 9 blinks. The best solution is get a new M board (about $ 60-80). The part number is on the board. It is nearly impossible to do a good job replacing the IC (80 tiny pins to solder in place) ---------- Eagle2
q605 avec un bon fer une base et souder toute soudure suspecte ca fais plusieurs que je repare cest toujours le meme probleme et tous va bien apres
had the ****** for 5 yrs. Any idea how to dispose of the heavy metal? (No offense to music fans.)
I also have to same problem but where I can buy the parts
Q605, D647, D690. When I google it I couldn't find any.Can some one give me the part numbers???
KV-32FS120
My 3yrs old son was pushing the power botton on and off several time on My (Sony FD Trinitron Wega KV-32FS120). whenk i tried to turn it on...
Sony Trinitron KV-32fs120 Does Not Turn On
Hi. I have a Sony Trinitron KV-32FS120. When you press the power button it does not turn on, no sounds or picture, and the stand-by light...
how do i take my sony wega trinitron off stand by
Our Sony, wide screen, trinitron model number
Our Sony, wide screen, trinitron model number kv-h34hs420 tuns on then off and the stand by/timer ( red) light blinks 6 times
Add Your Solution
need free service codes
tv going bonkers
Purchased T.V., used and need Parental control...
Unlock Parental control on a Sony FD Trinitron
Fix-O-Meter
5,360
5,360 people viewed this problem
- 35 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Sony Standard Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Ok, I have fixed the problem on my daughters TV. I checked all voltages pulled the caps from the zero crossing circuit. Everything was good. The problem with this model is the large parts due to poor wave soldering. The repair is free: locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down. This is an easy fix and free. You do not need the $20. repair manual that I purchased. Heck it don't even cover 9 flashes... It dont explain the ZC error that is on the screen when the tv is diagnostic mode. Fix it and be happy.
Roy M. M bsee
