Question about Toshiba 57H81 57" Rear Projection Television
My toshiba big screen tv is shaky and blurry
Need help with my toshiba theatre screen tv. the picture is not clear it is shaky and blury
  • 273 Answers
Most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Posted on Jan 20, 2009
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Blurry shaky pic
It sound like you have a leaky capacitor in your power supply, or video circuit, that is causing noise in the picture. I would have to refer you to a television technician in your area. This would seem like a simple repair. Leaky capacitors can become stable after they warm up.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 01, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Big screen on bad red lineand blury
Good DAy, mitas;
It sounds that the TV is having a Convergence Circuit problem or you may CRT Coolant (fluid) on the PCB's. Good Luck, big IRISH........ PS Call for help, by calling a Factory Service Center....get an estimate!!
Aug 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 50H71 Projection TV
I would check the power supply and the tuner section. This sounds like the low voltage powers supply is going bad or that the tuner section might be going bad. Does the picture fade to snow? Also I would suggest that you let a TV Technician take a look at the TV to determine what is happening. Most likely it is the power supply.
Thank you,
I hope this helps,
Shuttle83
May 27, 2008 | Toshiba Televison & Video
Blurry pictures
try having other people take a picture with your phone, if they can take a more clear picture, it is likely that you are just a little shaky when taking pictures (i have the same problem)
Jan 31, 2008 | Motorola Mobility L6 Cellular Phone
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
1,177 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
