Question about Panasonic 32 TCL32C3 32 LCD TV
I'm trying to feed a TC-L32C3 from a DVD player. Connecting with a coax sometimes works but most of the time I get a "No signal" message. With HDMI I can't choose HDMI1 - it's greyed out. No picture or error message with HDMI2. TV and DVD player worked OK before I got a PVR
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
  • 380 Answers
SOURCE: I have two hdmi devices (dvd player and pvr). The
Replace that Hdmi board.
Posted on Dec 20, 2009
SuperTech-11
  • 1591 Answers
SOURCE: panasonic TC-L26X1 TV suddenly stopped
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case I'd concentrate on the power input board.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 12, 2011
Need to know if Panasonic TC-L32C3 is a smart TV?
The Panasonic TC-L32C3 is not a smart TV. There is no network connection available (wired or wireless). It does have a slot for an SD card to make it a 32" photo viewer. You can also update the firmware by placing the unzipped file (see the site listed below) on the SD card. You can find the specifications and user guide on the product site: http://shop.panasonic.com/support-only/TC-L32C3.html . The direct link to the manual is ftp://ftp.panasonic.com/television/om/tc-l32c3_mul_om.pdf .
I hope this helps.
Dec 06, 2016 | Panasonic Televison & Video
Plugging a DVD player into a RCA J25435?
The DVD player should have a coax cable output on it, You can switch its output to either channel 4 or 3. This channel 3 signal should play on your TV. murf427
Aug 04, 2012 | RCA Televison & Video
Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV by Panasonic
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
Sep 27, 2011 | Panasonic Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Connecting coax to my DVD/VCR combo
For the DVD portion, you need to use either composite, component, or possibly S-Video or HDMI. DVD players do not utilize coax, since they do not incorporate tuners. However, since you have indicated it is also a VCR, it should have a coax input/output for that. perhaps it is a player only and doesn't have a tuner? But I have never heard of this in a combination unit. At any rate, if it truly does not have a coax input, then you will have to leave the coax connected directly to your TV and use the above mentioned connections between the home theater, TV, and DVD/VCR unit. Audio between the DVD/VCR and home theatre, and video between the DVD/VCR and TV
Sep 04, 2008 | Televison & Video
Connecting coaxial cable to dvd-v9700
I was thinking of using the RF modulator box, but in this case, it might not work, since signal should be coming from the cable box. What I dont know if there is a converter for signal from a coaxial cable to an RCA. However, the only way to connect is via RCA.
Sep 06, 2007 | Samsung DVD-V9700
Panasonic 32 TCL32C3 32 LCD TV Logo
15 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
