Renting property and no instruction's for this range. Tried to turn oven on and would not light. Holding the oven control button in the electric ignitor would glow. No smell of gas! Help me! Thank you, Al Wilkes
SOURCE: Brand new gas range
i would look into the valve/regulater at which you connected the gas line, off to the side or somewhere on the regulater itself there should be a shut off for the oven control, simply flick to open positon and you should start right up. it would shut off gas to oven but allow burners to light.
SOURCE: DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
SOURCE: I have a Hotpoint RGB745 gas range everything
The ignitor gets weak and dim and does not allow for the safety device to open and let the gas flow. The igniter must pull at least 3.2 amps. I have a short video HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Yes, this sounds exactly like exactly what is going on with the igniter. Thanks so much for your advice! It is well appreciated"
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
SOURCE: Gas oven will not light.
heatman101
Testimonial: "Thanks! I thought that it may be bad, but wasn't sure since it would glow red."
