Question about PNY VERTO GEFORCE 6600GT 128MB DDR3 PCIE DVI-I/VGA HDTV Graphic Card
CPU fan problem
The cpu fan is making very loud grating noises on start up, then quiets down somewhat. I managed to get some lubricant near the shaft, but it is still making noise. Where can I get a replacement cpu fan and heat sink if necessry
    Scholar:
  • 88 Answers
The stock fans that comes with systems are usually fairly poor in construction and tend to fail. I would have a look at the fans and heat sinks on this website for a replacement.
I hope this helps,
Thanks for using FixYa,
Eric
Posted on Jan 20, 2009
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Normal Operation
Troubleshooting
Solution
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
My dell inspiron 530s wont boot. just beeps and the fan (?) constantly sounds! grateful if you could help
I would check to make sure that the heat sink compound between the Heat sink and CPU has not dried out. This paste is supposed to stay somewhat soft and conducts heat away from the CPU. It can be purchased at Best Buy if you need some. Had the same problem recently with a Acer desktop. When I started it up the CPU fan just took off and would never slow down. Never could get windows to load either. Cleaned off the old compound using regular alcohol and put in new compound and it was quiet as could be. Windows loaded right up and it is working great. Heat is a major issue with the speed of CPUs these days. Hope this helps
Dec 12, 2010 | Dell Inspiron 530 Desktop Computer
I need a new cooling fan, how much are they?
The old addage "you get what you pay for".....It applies here. You can get 80mm to 120mm fans for under 20 bucks, but depending on how fast they have to spool up to keep the processor cool and how well their blades have been designed determines how loud they are, especially if they have been cheaply made....poor bearings and poor blade design equals noise. Bigger fans are actually a lot quieter because to move air they do not have to turn as many rpms. Get the biggest best made fan you can that will sit confortably in the case without interference. Also, download the little program called Speedfan, it will monitor fan speeds and system temps and make adjustments to the fans to keep them in the quiet range when possible.
Jan 16, 2010 | Sony CPU FAN CPU Fan
Fan is loud
well if its not attached to the motherboard in any place, for example the heat sync, or the cpu, then you can remove the fan, any other place, you shouldnt replace it because the mother board sets the fan at a certain rpm, and which would sound loud with any fan. I know this because i replaced the fan on my sony computer, and on a generic motherboard, and it was quiet, but when i put it on my sony computer, it was loud, so if you want to replace your fan, i suggest liquid cooling, it is completely quiet, and keeps your cpu much cooler than a fan. Best of luck.
Jul 04, 2009 | Computers & Internet
GX280 - is it the motherboard?
Go here and download this program.
http://www.download.com/SpeedFan/3000-2094_4-10067444.html
This program will control your fan speed based on your cpu temp. It's main use is to quiet fan noise.
Dec 15, 2008 | Dell Optiplex GX280 (99301) Motherboard
Loud Dell desktop
Any fan that is making noise you would need to replace. There is also never a need to use alcohol to clean a fan. Some computer air or a light wipe down will do just fine.
If you have any other questions let me know.
Thanks,
Lee
Jun 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
High pitch noise coming from laptop
Likely it is the system cooling fan or processor cooling fan so check to see if you would like to put it back under a manufacturer warranty if possible or whether you have the skill to review, follow, and carefully open up and inspect and clean and reassemble your notebook PC. What price is it worth to you to fix this problem - the downtown computer retailer that sells CDs and PCs and appliances will charge you to fix it. Again, most likely it is a simple small fan inside the PC. It could just have lint, dust, fuzz in it and after a clean out could work quietly again. The CPU cooling fins or cooling fan blades after cleaning will allow the CPU or system to operate more coolly, and then the fan RPM could drop a bit and the notebook PC whining sound may decrease. Oh, finally, putting the notebook PC on a grate or grill or a notebook cooling ventilation platform could alleviate the problem if it is just lint or dust.
Jun 04, 2008 | Compaq Evo N610C Notebook
Loud CPU fan
check your cables. it may be in the way of the fan's fins. also clean your fan for dust.
Sep 16, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
271 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
