Question about Plumbing
Moen tub faucet handle will not come off
Went to remove set screw ....it striped out. tried to drill out ... will not drill out.... mad and frustrated
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
dragonsthatk
  • 547 Answers
SOURCE: Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Posted on Feb 26, 2009
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
Handle dome keeps coming off
Sounds like the setscrew that holds it on has either worked lose and is missing or is striped and no longer tightens properly. Replace set screw if missing and or replace set screw if the set screw is striped. If the threads are stripped in the faucet body the faucet itself will need to be replaced. This usually does not fall under Moen's warranty guidlines.
Mar 29, 2014 | Moen 7594EC Arbor Single Handle/Hole...
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
Cannot remove handle. Allen wrench receiver is stripped. Are there any other options? Thanks!
There is a home cleaning product called the The Works which will loosen the corrosion around the screw. Then use a screw extractor tool. You can find one at most hardware stores and home centers.
Another solution would be to call Moen Customer Support and ask for a new handle and repair parts for free. The faucet should have a lifetime warranty. When you have the new faucet parts in hand, literally cut the handle off the faucet with a hacksaw or drill the screw out to remove the handle.
Sep 07, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Best way to remove a stripped set screw from the handle
drill it out, use a bit that is smaller than the threaded part of the screw and use oil on the bit to prevent over heating
Mar 21, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
How do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Feb 12, 2009 | Moen Castleby Two-Handle Widespread Roman...
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
