Question about Toshiba Satellite Pro M15-S405 Notebook
Problems with the monitor. the ven is not working. pc is startingup but the monitor is blank
  • Anonymous Apr 02, 2009
    Me too!
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Please clarify for us: is this indeed a Toshiba Satellite notebook as this is headed under? Does the screen on the notebook not even show the "splash" when turned on? Does the notebook appear normal when connected to an external monitor?
I have a gateway FPD2485W tft lcd monitor and i start my monitor and after it shows gateway it then goes black. How can this be fixed
bonannorl, Maybe it can be fixed. You did not give any history of unit. Only "now" stuff. Is unit covered by Gateway warranty? How old is unit? Date of manufacture? Did unit work fine connected to your pc and this black or black n blank screen thing suddenly happen? Is screen also BLANK? Have you swapped-in old monitor to prove PC is OK? Your CCFL back-lit lcd monitor no different than any other brand in it's basic design and operation. Get into my fixya profile and read some of my testimonials and solutions to black or black n blank screen problems to help in your decision to DIY fix or contract out needed repair work. Most likely 2485w has problem with it's internal "switch-mode-power-supply"/"ccfl inverter supply"!! Let me know more info about unit.
12fixlouie on fixya.
Mar 09, 2010 | Gateway Computers & Internet
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
No display, screen is blank even compuer is running
Can I assume (?) you re-tried firmly checking each cable connection and the power supply is soundly in place including checking the fuse in the plug That's all I can suggest as the things I would do if in your shoes.
Aug 05, 2017 | BenQ FP72G (Black, Silver) 17 inch LCD...
Viewsonic VX912 Distorted screen
for meantime use the previous monitor suitable to your pc then download the files you need enabling the new monitor to work.
Oct 15, 2008 | ViewSonic VX910 19" LCD Monitor
Display Problems
your gpu has failed - thats graphics processing unit. new m/board required
Jul 12, 2008 | HP OmniBook XE3 Notebook
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Toshiba Satellite Pro M15-S405 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
