Question about National Detroit Model Da Dual Action Air Sander With 6" Pad
Customer has a da sander .... says the number on bottom is DA498995 ..... i can't come up with this number anywhere ... he is looking to replace "block that attaches to sander".... any input would be welcome! thanks, marti
  • 165 Answers
Http:// try this site hope it helps
Posted on Jul 07, 2009
D.A. Sander part
what is the make and model number?
Jun 11, 2013 | Northern Industrial Tools Air Tools &...
Have an 80 Gal. 2 stage compressor outside, below freezing temps with 100% humidity. Running 2 DA's, they keep losing air pressure inside the DA's, hose pressure is good but DA will not let air past the...
First bring that compressor in from the cold. Any water it collects in the tank is freezing and reducing the volume of air it can hold.
Second, it sounds like water is getting to the DA and freezing at the inlet. Will also be solved by bringing the compressor inside.
Third, put the filters at least 25 feet from the compressor if possible. And make sure all lines from the compressor to the outlets are running a little up hill. This way any water that gets in the pipes will run back toward the compressor
Fourth, At each station have at least 4 inches of pipe below the fitting with valve on the bottom. This way any moisture that gets to the end of the pipe has someplace else to go rather than the air tool.
This will not only make your tools run better but they will last a lot longer.
Feb 28, 2011 | Ingersoll Rand 6? Dual Action Sander #...
Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
May 23, 2009 | Chicago Pneumatic 864 6" Heavy Duty Dual...
Lost instruction manual
Go to this web site, and enter the model # of your sander in the box in center column, near bottom of page.
If this doesn't take you to a manual, enter model number to see parts list, and look in upper left of parts diagram page and there's a link to manuals.
If I've actually managed to answer your question or solve a problem, please take a moment to rate this post....thanks!
Mar 29, 2009 | Black & Decker Black And Decker Cyclone 4...
Replace sanding pad on random orbital sander dw443
You will find usually 3 torx drive screws on the bottom of the tool, remove them and the pad comes off. The replacement pad number is 151416-01 list 27.49. Let me know if I can help further
Feb 23, 2009 | Dewalt heavy - duty6" right angle random...
Air Sander tips
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Taylor Pneumatic: DA Sanders: 10000RPM....
National Detroit  Model Da Dual Action Air Sander With 6" Pad Logo
265 people viewed this question
Top National Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a National Air Tool and Compressor Expert? Answer questions, earn points and help others
