Question about Microwave Ovens
Magic chef mco160s microwave control panel not working
Microwave was stopped on 53 seconds while cooking. Unplugged it and plugged it back in. Light works and clock comes on but you cannot set the clock and none of the other buttons on the control pad work either. The microwave also started by itself without pressing buttons and was on for about a minute and then quit.
  • Microwave Ovens Master
  • 9,086 Answers
That would be a defective membrane keypad.
If it's still available, and you or someone you know might want to replace it, here's a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag in or on the microwave here.
Posted on Jan 09, 2013
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
Posted on Jan 03, 2009
  • 82 Answers
SOURCE: Magic Chef won't work - clock works
Does the fan run?
If not, it's a control board fault.
If it does run, it's probably a high voltage problem.
Posted on Mar 16, 2009
  • 119 Answers
SOURCE: none of the buttons are working; unplugged and
Depending on the model its down to the keypad
Posted on Feb 13, 2010
  • 11800 Answers
SOURCE: Magic Chef MCO160S 1000 Watts
The buzzing comes from the transformer - it's overstressed by a short. You will have to open it and find out the shorted part. I strongly suggest that you either junk it or take it to an specialized repair shop - the voltage inside it (in excess of 5000 volts) can easily kill you if you even come near to it. Your life is worth more than a few hundred bucks.
Posted on Oct 10, 2010
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave refuses to work when
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Posted on Jan 11, 2011
Magic Chef Microwave has stopped working. None of the buttons work. It's showing random numbers when you plug it in. I tried a different outlet and it gave me different numbers.
Try unplugging it for 24 hours. Plug it back in and see if this helped. If it's still the same, it needs a new control PCB (printed circuit board).
Oct 16, 2013 | Magic Chef Mcd1811st 1.8 Cubic-ft,...
My magic chef microwave starts but immediately stops light work tho
No solution but keep it unplugged until you find one. Some units can cause a fire.
Feb 14, 2013 | Magic Chef CMV1000B Microwave Oven
MCO160 microwave and cook vent appliance problem--there was a power surge and now only the light works--is there a reset button?
no reset button. if you are getting lights that means you are getting power and all your fuses are good. you may have a bad control board caused by the surge
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
Only 1 function works at a time on mco16
That actually sounds like correct operation in that you cannot use the timer while it's cooking.
Assuming yours is model number is MCO160S, you can download your owner's manual here if you don't have it.
Page 19 tells you how to replace the cooktop lights and the cavity light.
Dec 13, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef Microwave Model MCO160S .
You can download that manual here.
Nov 25, 2008 | Magic Chef Microwave Ovens
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
