Question about Hitachi 50VS810 50" Rear Projection HDTV
Screen isnt clear
It looks very red
  • 273 Answers
You have what is called a optic block problem
it will have to be replaced to correct the problem
if your the original owner you might want to contact hitachi consumer relations and see if they would offer some assistance with the optic block assy
you would be responsable for the labor and tax,s but still would give you your set back at a fair cost
Posted on Jan 20, 2009
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
Red light is on and subwoofers dont play but regular speakers play
when you say redlight is on it isnt very clear as the power light for the amp is red...right above the cooling fan are 2 indicator lights and if either of them is on your issue can normally be addressed by faulty wiring, you may have wired the speakers at at an ohm load the amp isnt made for which over time will blow the amp if not right away. Also if you dont have inline fuses and such setup i the system then something as simple *** a power surge could have blown the amp...again since the power indicator(red triangle in the center of the amp) is red it could always be that your head units RCA outputs are bad if you have any hooked up at all.
Sep 06, 2010 | Kenwood eXcelon X1200M Car Amp
My microsoft optical mouse isnt working on my lap top the red light is not working anymore so i cant get on my laptop so how do i fix it?
Replace worn out batteries in it. If that isnt the problem then access the BIOS screen by booting laptop up and pressing DEL key, search for setting that lists infra red laptop pad, enable and save / /reboot.
Mar 10, 2010 | Microsoft Wireless Notebook Optical Mouse...
Whirlpool Dryer Model No. GEW9250PW. Dryer frequently fails to completely dry sheets and bedding no matter which cycle is used.
It could be many things check your vent to make sure it is clear all the way out the house,take your lint screen out and scrubb it with a brush it my look clean but it isnt.
Nov 15, 2009 | Whirlpool GEW9250P Electric Dryer
No red pigment on Screen
Pull back to TV turn on watch to see if all 3 tubes are lighting up if Red is lighting but no red CK projection Fuild in Tube, look down into lenses if you cannot see pictue clearly then Fuild is Bad.
Sep 21, 2009 | Panasonic Televison & Video
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Dec 21, 2007 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Pic on tv
i problem with tv by that icant get pic from tv
Oct 28, 2006 | Samsung HC-P4363W 43 in. TV/DVD Combo
Hitachi 50VS810 50" Rear Projection HDTV Logo
108 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
