Question about Dishwashers
Omega dishwasher dw 2002 eb
Dw 2002 eb
3 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Diswasher wont turn back on after being moved - DW Omega 908
Have you checked the door interlock switch to make sure it is not disabling the wash cycle?
Posted on Sep 01, 2008
  • 154 Answers
SOURCE: Omega Technowash Dishwasher. Model DW
Hi
You most likely have a fault with the Thermostat. That is common on Omega Technowash which is similar to a Smeg dishwasher. More often than not the Thermostat fails rather than the heat element. However, not to completely dismiss a failed heat element.
The thermostat is not very expensive. If you don't have the means to test the element or thermostat via a multimeter, you can order the thermostat to have a go at fixing it yourself.
Unplug the machine from its power point.
"Two screws in the front kick plate. Open these and lift off kick plate. When you open the dishwasher door you will see an L-shaped heat element which is on the bottom of the bowl on the left and back of machine. The Thermostat is the round metal head situated on the front left in between the element coils. When you look from underneath inside where you have removed the kick-plate you can see two wires going to your heat element and 4 wires going to the Thermostat (either 2 White and 2 purpule) or (2 red and 2 white).
The thermostat is pushed in from the bottom and sits in a groove of a rubber seal. You can pull it down and out from underneathe and twist and push up the replacement in its place. Make sure the sharp metal edge of thermostat is poped insided the groove, otherwise the machine will leak.
Try this first, I am fairly sure it is the thermostat. If you have a multimeter you can check continuity of the heat element.
If you think this solution helped you please vote 4 thumbs up and give me a testimonial.
Thanks
Ash
Posted on Sep 22, 2011
Replace dishwasher
Is your DW plumbed into the garbage disposal as many are? Or does it have the drain line running into a pvc opening in the sink drain line? Remove the drain line to see if water gushes out. If no or minimal water leaves your drain line from the DW, then the problem is internal in the DW. Most likely cause is a plugged screen at the inside bottom of your DW, or the pump is blocked. Best way to resolve is to get a wetvac and just suck all the water out of the inside before you remove the DW. Otherwise you will have water splashing out on your floor. If you can see the screen is plugged up after doing so, then pull the screen out and then turn the DW on. If operating normally it will go into the pump out mode first before adding any water. Turn off the water to the DW under the sink first to eliminate any concern about adding additional water into an already filled up DW. Good Luck!
Feb 16, 2017 | Dishwashers
Omega Technowash Dishwasher. Model DW 2005 WH. The electro-mechanical timer stops just after the dishwasher powder is released and again near the end of the cycle. Also the water is not heated and no...
Hi
Thanks
Ash
Sep 22, 2011 | Dishwashers
Dishwasher clean light is blinking
indicates a problem with dw not heating the water. various causes. dw should be thoroughly checked, if nothing found wrong, reset computer
Jan 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
The first cycle water is not hot - all other cycles are hot - the water in the sink next to the dishwasher is not???
Where does the dishwasher connect to hot water? If it is connected to cold it must be changed. From your description, the water is coming from a long way off and has to warm the pipes as it travels to the dw. The dw should have a heater to bring the water up to temp after filling before it runs, if this heater is not working, the first run will be cold and the next hot because you have drawn enough water through the pipes to bring hot water to the dw.
1. Change where the dw gets hw.
2. Run hw in the sink before allowing the dw to start (if connected to same line).
3. Fix the dw's water heater.
Three possible fixes. Good luck.
Aug 27, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Sep 01, 2008 | Dishwashers
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
Owen Barnes
