Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Saw only runs when it is upside down - Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
2 Suggested Answers
snowghost1
  • 784 Answers
SOURCE: My saw will run for
I have had this happen several times with the Husqvarna saws that I work with out here at the lodge I work at and 9 times out of 10 it is a small ****/break in the fuel hose inside the fuel reservoir that is sucking air and not getting fuel. I have also had a problem with the little filter on the end of the intake hose ( inside the fuel reservoir ) and it is not sitting at the bottom of the reservoir.
c...
Posted on Jan 19, 2011
My desktop is upside down, how can I fix this?
You can turn your screen back to normal by pressing twice the keys Alt + Ctrl + arrow key (->).
GuruAid.com
Mar 14, 2015 | Computers & Internet
Upside down backwards
sorry have never seen one and we can not fix what we never saw .
Nov 17, 2017 | Baby Gear
Ryobi mitre saw - saw dust has collected inside base making it extremely hard to move the saw angle horizontally.
Flip the saw upside down ,and loosen the bolt on the bottom. Now blow the sawdust out.
Sep 18, 2011 | Ryobi Garden
I have just bought this model second hand, and the blade is fitted upside doen for some reason. How do i change blades?
Hi marill469,
Here is a website where you can download the owner's manual for your saw: http://www.retrevo.com/d/ds/progress?doc=e045b5a9143e1e2ea028b778addd77ca&rk=0.7594880065395843
The instructions for blade insertion and removal are on page 7.
As far as I know, there is no upside down on a recip saw blade. You can use it either way. Upside down allows you to get the blade in tighter spaces due to the shape of the saw.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 19, 2011 | Makita JR3050T Recipro Saw 9 Amp
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
Blade running the wrong way
the field is in upside down, remove it and rotate it 180 degrees. Let me know
Nov 05, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Miter slots on table are not parallel to blade
Either the saw is a cheapo and you can't do anything about it. If it is a better quality saw it should have at least four bolts or lugs where it it fastened to the table. Turn it upside down and locate those bolts. Loosen them - don't remove them- and turn it right side up. Now shift the motor assembly around until it is parallel with the miter slot. Make sure it is unplugged the whole time. Turn it upside down again and tighten the bolts. Recheck it and if it moved repeat the procedure.
Nov 03, 2009 | Delta Saws
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
204 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
