Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv turns off and comes on
Rca 56 inch rear projection the power will turn off and then it will turn can you tell me what is the problem
  • susan7444 Jan 22, 2009
    My RCA also clicks off and back on. Then will click off and stay off. It makes a loud poping noise when it clicks off. This occured 1 1/2 years ago and was then fixed, but is doing this again. Is it a recall problem?
Have u been using the buttons on the front?
if so it could be the button is stuck on the tv..
or possible a short in ur remote..
Posted on Jan 20, 2009
What kind of heat issue would my 56 inch projection tv have if after a couple hours shut off and on then then turns off . fuse, power supply . not sure
Sounds like it's possibly your convergence IC's overheating. On some projection tv's, after time, the solder joints on the IC's weaken from the heat and cause them to turn off the tv for it's own protection.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
I have a 56 inch rca rear projection tv and after two hours starts turning of and on for about half hour and then turns off. when we turn it back on it shuts off and comes on fast and then shuts off....
Those type of tv sets get unusually hot at times. Could be a heat issue. Power flow at night is the best. If it's still turning off then, it must be a dust or heat issue.
My rca 60" projection tv turns on and has sound
I had a 56 toshiba do that and it was the light bulb inside. It wasn't difficult to replace.
Nov 14, 2010 | RCA P61960 61" Rear Projection Television
My rca model d56w20 56 inch tv wont turn on
Usually its the CP150, CP120 and the CP114 capacitors that will cause that symptom. You can get the RCA repair kit by that same name from www.tvrepairworld.com which does include the repair instructions.
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
We have a 52 inch RCA projection HDTV and today it just stopped working. It doesn't turn on at all. There is no power light or sounds or anything coming out of it. It was fine the night before and when I...
I had the same problem which got fixed today. It was a loose connection to the power supply unit that required some soldering by a technician and cost me 56$. My TV works after 2 months.
Aug 28, 2010 | RCA D52W23 52" HDTV CRT TV
I have a 56 inch rca that blinks three timeswith a humming noise but wont turn on
The 3 blinks (an error code) and the hum (most likely from the flyback) indicate that the flyback transformer is bad and needs to be replaced as the simple way of putting it (fairly common problem with projection tvs). If you plan on doing it yourself, then you should have some electrical expertise since working in a projection tv like this can be very dangerous otherwise I would go through the local shop. Let me know how this turns out for you.
Benjamin
Jul 18, 2009 | RCA D56W20 56" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
