Question about Dishwashers
Logik dishwasher codes
I've got a fault code e1, what does this mean
Turns out hey have like a pan on the bottom that catches water, empty that tray of water, turn off at the plug and hold the power button, turn back on at the mains and start it.
Tilted mine up so the water ran away, done the power as above. no more E1 error code.
Posted on Sep 08, 2017
5 Suggested Answers
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
SOURCE: Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Posted on Mar 22, 2010
  • 3 Answers
SOURCE: lg dishwasher ld2120w is displaying
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies.
Add a comment
Posted on Nov 07, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Looking for fault codes F-7, E-5 and F-5, E1
    We don't know what brand you have, so Google (brand) washer fault codes F-7, E-5 and F-5, E1 As you indicate you have a Maytag, that means this search: https://www.google.com/webhp?hl=en#hl=en&q=maytag+fault+codes+ Those specific codes are a lid switch and Shifter actuator fault
    May 14, 2016 | Washing Machines
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    Error code E1 and E4
    PDF]SERVICE Manual - Quietside
    https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
    When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
    Midea air conditioner error codes
    airmaster.net/midea-air-conditioner-error-codes/
    Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
    [PDF]Download the Fault Error Code Booklet - Samsung
    Dec 05, 2015 | Heating & Cooling
    Haier service manual
    This is what you error code means.
    E1 = Room temperature sensor fault
    Haier Air Conditioner Fault Codes
    AC Repair Tamarac
    Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
    Oven flashing F and E1 codes when i turn oven on it ays to turn oven off and flashes F1 nd E1 codes
    If this is a Kitchenaid, Roper or Whirlpool range, this error indicates an EEPROM error in the control board. Ifthe F1 E1 trouble code continues after you've disconnected the power for over 30 seconds, you need to replace the electronic control board (clock). You can often find parts online with the model number of the unit. (Try partselect.com or searspartsdirect.com (if Sears sold the model).)
    I hope this helps.
    Oct 25, 2011 | Kitchen Ranges
    Where my clock was on my stove a E1 F-5 came up and my oven won't work now. The top burners are working but the oven won't. We don't have a manual for troubleshooting. Can you help me?...
    F5 - E1 Self clean latch will not lock
    2. If door not latched:
    1. Disconnect power from unit.
    2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
    3. Repeat steps A and B for door switch
    Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlkkZwU
    Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlaiwL3
    Sep 04, 2011 | Kitchen Ranges
    Error code E1 what does it mean
    The problem is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in troubleshooting this error code.
    Troubleshooting Error Code E1 on Whirlpool Duet and Kenmore Elite Dryers
    Aug 27, 2011 | Kenmore 62602 Electric Dryer
    A code E1 flashes the dryer shuts off and the clothes are still wet
    The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
    Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
    Oct 25, 2010 | Kenmore HE5
    Dishwashers Logo
    1,594 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
