Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Power supply is the unit size something I need to be really worried about
    Problem Solver:
  • 8 Answers
What you need to be concerned about with Power Supplies is the Wattage (The higher the better) and its "Form-Factor." A Form Factor is the general size and shape of the motherboard. The most commonly used Form Factor is ATX or Mini-ATX. I would reccomend figuring out what size your case is either ATX or Mini-ATX (Baby-ATX sometimes) and you should be able to decided whether the PS is too big. Too small isn't a problem as long as you can screw the unit in tight.
Posted on Jan 22, 2009
EMachines 820 desktop
You can fit just about any motherboard in the case but would probably only consider an ATX or Micro ATX. ATX is the largest physical size mobo followed by the Micro. You wouldn't need to worry about anything smaller as they are more expensive anyway.
I would be inclined to replace the power supply also as that will be 'tired' and would probably struggle to power the new board. I never fit anything less than a 500 watt power supply. They're not that expensive anyway and it's always better to have power to spare than to be on the borderline.
Apr 25, 2015 | Computers & Internet
Dell inspiron 560 power supply problem
This could be either power supply or motherboard problem. If the fans on the motherboard and power supply are spinning then it's probably the motherboard which you can check by removing the memory and unplugging the data lead off your hard drive. It should start beeping.
If not, then it's probably the power supply. They are easy enough to change - half a dozen plugs and four screws. I always replace standard power supplies with a 400 watt one. It will tell you the wattage on the label, I would add 100 to that figure and get that size or bigger - depending what's available.
It will not hurt to replace a 250 watt unit with a 500 watt unit so don't worry about that. It gives you room for expansion.
Jan 15, 2013 | Dell Inspiron 560 PC Desktop
Power supply
You can go as high as you want. Typically the higher the wattage, the more devices you can add as motherboard inputs are standardized so it won't make a bit of difference to the motherboard just so long as you stick with ATX power supplies. So you could go to 650w or even more and it won't make a difference, although you won't need that much wattage unless you have lots of drives and a power hunger discrete graphics card.
May 06, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
It is a klh powered subwoofer, which buzzes when plugged in, even though the power switch is set to "off"
Sounds like the grounds are screwed up. Try using a grounded wire for the subwoofer input. If that doesn't work, it sounds like something is internally screwed up, like the power supply doesn't fully power down. I guess besides buying a new amp, just connect it to a power strip where the switch is accesable and shut the sub off with the power supply.
Oct 10, 2009 | Audio Players & Recorders
Same clicking Problem
Glad you worked it out cheap switch mode supplies can make a clicking noise when pooched. Now if the hard drive itself makes that noise you are in trouble. Almost any replacement power supply will do so long as it is capable of delivering not only the correct voltage but the correct current as rated in "mA" milliamps or "A" Amps.
You can of course exceed the current rating and quite often that can be a good thing to do as it may well prolong the life of the supply even if it may cost a few pennies more.
I can usually judge a good supply by its size and weight VS its power ratings. I like em large and heavy
Aug 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
When i turn on my emachines 420 at the mains, the led power light comes on, but it wont do anything else including turning on or off
Hello there,this sounds like a problem with your power supply unit inside the computer,emachines are always blowing there power supply because the one that comes with the computer just is not powerful enough.If you are confident enough around electrics you could nip into maplins buy a new psu for around £10 - £20(take the old one in and try to get one the same size and with the 3 pin kettle lead thing in the same place)if you cant dont worry you can make it fit somehow,dont worry about all the wires that are dangling about ,they are very easy to figure out where they go.I had a emachine computer a few year back the same thing happened so instead of scrapping it i thought i would try and fix it,you take the side of and it all looks complicated but believe me its a lot simpler then it looks(a bit like my boss really!)Anyway If you dont feel like you could give it a go then take it to the shop and they will fix it for you.If you need to know about anything else to do with changing the psu then let me know and i will talk you through it.Good luck.
Richie
Apr 28, 2009 | E-Machines eMachines Desktop PC
ASK Proxima c170 Power Supply Failure
I really doubt you'll find a generic power supply for this unit. I can repair this power supply for you at a low cost. I repair power supplies. My ebay ID is Gtitubro
Mar 02, 2009 | ASK Proxima C170 Multimedia Projector
Power Supply Connections
Not every wire that comes off the power supply is used so this might be worrying over nothing. I'd give a quick look at all your components inside- especially the cd or dvd players as well as the CPU fan. If it looks like everything is okay, power it up. When your system runs its POST (power on self test), it'll tell you if something critical is missing. If not, use it as normal. If something really is unplugged, later on you'll find out because it either won't work or a function of it won't work.
Aug 15, 2008 | HP Compaq Motherboard
Emachines M2350 laptop- no power
It's one of two issues. 1 - power supply. 2 - the power management chip on the motherboard. Since the power supply is the lesser of the two, try a new supply first. If that doesn't do the trick then it's the pm chip and the motherboard will need to be replaced.
*NOTE* The power management chip recognizes the type of power being used and allows the computer to switch between AC and battery power, it also allows the unit to charge the battery.
Jun 18, 2008 | E-Machines M2350 Notebook
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Apr 11, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
207 people viewed this question
Alun Cox
