Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG LDS dishwasher soap door does't open until you open main door
I have an LG LDS dishwasher and am having problems with the unit. I have owned the dishwasher for just about two years. The first problem was when it stoped washing the top shelf of dishes, after checking the arms and other things I could think about I started dissasemling the inside bottom of the unit. Upon dissassembly I found the water diverter valve that lets the unit was the upper and then the lower levels in two different stages. I found that this was not working, not allowing water to be diverted to the top. I manually moved the valve to allow water to the top and bottom. This has helped this problem. Now the soap door in the unit will not open until you open the main door at the end of the wash.
  • 350 Answers
I'd try cleaning the soap dispenser mechanism as good as you can with forced air or water then pour oil on the hinged areas and wiggle it a lot!
I'd also put a big sign on it to remind me to put the soap in after I unload the dishes!
Hope this is helpful!
Good Luck!
Posted on Jan 20, 2009
  • marcgolomb Dec 13, 2010
    One of the great mysteries of appliance life; Why does the soap door pop open at the end of the wash when dishes are done. The soap is gone, obviously having done it's job, but how did the door open and then close again? I am a mechanical person but this really jars me.
It will not turn on, we've checked the circuit breaker and opened and closed it several times, still will not turn on.
Check to see if your getting power at the main board. To get to the main board, open the door and remove all of the screws around the door. This wil allow you to take off the outside cover. The power wires are the black and white wires on their own terminal going into the board. Careful because they should be live. If you are getting power here, you will need to replace the main board, if not check the connections to your dishwasher where line voltage comes in, located on the bottom right corner under the kickplate. Hope this helps.
Jan 31, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
The detergent dispenser will not open during the wash. We have even tried washing with no detergent and it still will not open. How can we fix it?
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Dec 16, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
SOAP dispenser does not open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher started leaking. Water between door layers
Clean the surface with soap solution. If the door gasket becomes hard this will happen. Replace the gasket with the same make.
Jul 20, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
NewDishwasher LG LDS 4821 WW Normal cycle
The new energy efficient LG dishwashers take 2 hours from start to finish depending on water temp. Run your hot water at the sink prior to starting the unit.
I see all the time inproper loading of the dishwasher blocking the sray arms.
Put 1 teaspoon of detergent in the soap dish.
Run the unit without anything in it.
If the soap washes out the unit is ok.
Also here some improtant info. that often gets overlooked when a new dishwasher is installed.
Replace the water supply valve under the sink and water supply line to dishwasher.
Over time minerals deposit in the valve and restrict the water flow to the dishwasher.
This is especially inportant on todays water saving units.
Many people replace an old dishwasher and hate the new unit due to a white film left on dishes.
Although you may have paid for a professional installation a new shut off valve is almost never replaced even though the waterline may have been at an additional cost to you..
Jan 06, 2010 | LG Dishwashers
LG LDS 5811 has started leaking at the bottom of the door left hand corner.
Could be 1 of 2 things.
1: Open door and look for any" Obstruction" Between the Door Seal and the Dishwasher.
2: the Seal is Warped from General useage or, twisted.
hope that helps
Please Rate Me
George
Apr 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher leaking from front door..not gasket leak
Contact LG support number. Have proof of purchase info available, but even if the LDS 5811ST is out of warranty, explain the symptom then firmly but politely explain that you are aware of a retrofit program for the LG LDS and LDF models that fix the problem of poor drying and water leaking from the _door_ panel (Lower left area)
Insist that they schedule a service call (no cost) or replace your dishwasher with the retrofit applied.
Good Luck!
Mar 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS 5811 Dishwasher has white film everywhere.
You may have a water issue.  Be sure that the water line is connected to the hot water pipes, not cold water.  If your dishwasher is connected to the cold water, the soap residue will occur because it cannot dissolve in cold water properly.
Is your water very hard??  If so, you may need to get a water softener to remove the hard scales.
Jul 07, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
151 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
