Question about Kenmore Refrigerators
Kenmore model 76202
Refrigerator light switch sticks. can the switch be replaced and how can the switch be released from the refrierator side wall?
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 90 Answers
SOURCE: light switch on a older kenmore refrigerator, how to replace
Most light switches snap in place. If there is no apparent screw and the switch seems to have an adequate lip all around it, use a putty knife or butter knife push under that lip at one of the shorter sides and gently try to pry it up. It should pop out. the two wires are usually attached by spade connectors that just pull off. Doesn't matter which wire goes on each. Sears should be able to get a new one. But before you go that far be sure the bulb is not burnt out first. You should also take the switch with you to sears or have a friend test the switch to be sure it is truly bad..
Posted on Feb 15, 2008
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
VOTIT
  • 2071 Answers
SOURCE: Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Posted on Jul 05, 2009
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
My refrigerator Kenmore model 795 77563600 freezes up the vegies on the left side drawerand werever I store on top of that drawer. What can it's wrong with it?
Your refrigerator as cooling tubes that allows the cold air or the freezer to go to the refrierator side. If one becomes blocked with frost all the cold air is then forced to route through the other cooling tube. And that what it sounds like is happening to you.
Jan 04, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore refrigerator is not getting cold this morning there was water all over the floor the ice was metl
Someone would have pressed defrost switch. Please release the defrost switch. Or automatically it will release after some time. (Not so longer time). Then compressor will start to run and cooling will be there.
In case all of above attempt failed, check compressor running. If not replace relay. If compressor running and no warm on discharge side, gas leak. If warm and no whistling noise in freezer side chock on system. Both cases release gas, and leak test, arrest, vacuum and do gas charging. Replace filter drier.Thanks. Helpful
Jan 26, 2011 | Kenmore 50522 / 50524 Side by Side...
Light in refrierator won't work
If the light still didn't work and you are sure the bulb is good, then the next thing in line to check is the door switch. Off the top of my head, I'm not sure where the door switch is on this model, but the switches are usually at the bottom. Door switches are notorious for getting sticky. Lots of things get spilled in the fridge and run down to the switch. If the switch doesn't pop out when the door is opened, the light won't come on. Usually just working the switch and cleaning any sticky stuff from it fixes the problem. If not and you have a meter, you can check the switch. If it checks bad with a meter, then it has to be replaced.
Hope this helped
Jul 23, 2010 | Kenmore 57029 Side by Side Refrigerator
How do you replace the light switch?
Unplug the refrigerator.Take a small skinny flat screw driver and pry the switch out. You can unplug it once you have it out but hold on to the wire so it does not fall into the refrigerator. Have the new switch ready to install or tie or tape the wire while you go get the new switch.
Oct 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Freeer motor wont operate, motor ok,
check the connections to the sensors inside of te evaporator compartmnet to the freezer. the fan won't come on untill the evsaporator temperayture is 0 degrees. hAVE YOU CLEANED OUT THE CONDENSER IN THE BACK LATELY? it may be dirty.
Mar 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator will not cool
also the complete mod number would help
May 21, 2008 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
