My Canon F149200 (I guess that's the number) keeps telling me the Toner is not set. The toner has not been moved for two weeks. I have tried taking it out and puting it back in but nothing seems to be helping
  • jbryant502 Mar 27, 2009
    same issue as above, toner not set.remove toner replace toner, makes copies untill machine goes to sleep. go thru process again
  • Anonymous Apr 22, 2009
    toner is not set
Try taking the paper out of the tray, reseating the cartridge, then recycling the power - worked for me.
Posted on Oct 28, 2009
I have a canon ir3030 there is one side sightly dark and one side sightly light in same page i need solution?
Hi
You will probably need to replace the toner cartridge.
If you are certain it is not nearing empty, try removing the cartridge, putting in a plastic bag and giving it a little shake. Then clean the area around where the toner comes out both on the cartridge and on the printer.
That might help a little, but generally once it starts fading it means you are coming to the end of the toner/ or possibly fuser unit
You might also try changing your settings to print higher quality. That might allow you to get a few prints out a bit clearer, but will also speed up the demise of your cartridge
Mar 27, 2015 | Canon imageRUNNER 3030 Black and White...
Canon 1r 2016 toner out indicator even after puting fresh toner,replaced dp unit still same problem
try to change the drum. (drum unit yield 50k)
can you tell me the total page number?
Sep 25, 2009 | Canon iR 2016i Black and White Copier
CANON MF6550
The error you are describing is usually cause by a bad cartridge but if you have tried a new Canon cartridge because refills will cause this a lot then we would need to look internally. If you look inside the unit (cartridge removed) on the right hand side towards the bottom you will see 3 flat metal plates. These are called spring plates when you push on them they should move in and out check and make sure they are not bent or depressed in you can try and use your fingers to fix them if they are. If not this unit would still be under the 3 year manufacture warranty call Canon they should give you service options. 800-828-4040
Jan 28, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
After replacing the toner cartaridge, the error light comes on. In the little box, it says toner is not set. Insert toner. I have readjusted it several times. It seems to be set solidly. The problem...
You have to:
1. take paper out.
2. remove the toner
3. place the toner back
4. printer will "initialize" itself.
5. put the paper back.
Totally crazy!!!
Jun 30, 2008 | Office Equipment & Supplies
Canon NP6050 Error code E013
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
Dec 07, 2007 | Canon NP 6050 Copier
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Canon LBP 3000 tells me it needs a new toner cartridge
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go. Our IT man rocks!
Sep 23, 2007 | Office Equipment & Supplies
Toner not set
"Take out the paper from the machine and the toner cart unplug the power cord for 10 seconds then plug it back in that will fix it"
This solution worked for me but actually unplug the machine not just turn it off.
Jul 17, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
2,723 people viewed this question
jasbo
jasbo
