Question about Seagate Barracuda ATA V (ST330013A) 30 GB Hard Drive
What is the drive settings for slave and master
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Installation of the drive and setting of jumpper
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Posted on Sep 27, 2011
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
slave :::':
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
Installation of the drive and setting of jumpper to make it either as a master or slave
slave :::':
Sep 27, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
S.smith1@hotmail.co.uk How do I slave HDT721050SLA360 500GB 7200rpm
if you want to set a master / slave on you computer
slave :::':
Aug 26, 2011 | Hitachi Deskstar 7K1000B HDT721050SLA360...
What are the jumper settings on the drive for the following? Cable select Slave Master
For Slave/Master set up most hard drives have a little diagram on them showing you where to put your jumpers for master and where to put the other one for slave. All hard drives are different. But on your diagram it should say "MA" for master, "SL" for slave and "CS" for cable select.
For Cable select you have to set jumpers to cable selected which should be on the diagram on your hard drive. You will need an 80 conductor IDE/ATA cable. The master conductor is at the end of the cable and the slave conductor is in the middle.
Mar 25, 2011 | Computers & Internet
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
I would like to make this a slave so that my 500 GB PATA HardDrive will be the master as that has my operating system and the Plextor PX-716A drive will be the slave?
You need to configure the jumper at the back of the drive as shown in the following picture
Configure the CD/DVD drive as slave, configure the hard drive as Master.
Mar 13, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Seagate Barracuda ATA V (ST330013A) 30 GB Hard Drive Logo
19 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
