Question about Irons
Where to get filter for hyundai steam generater iron
5 Suggested Answers
  • 833 Answers
SOURCE: Tefal Pro Express Steam Generator Iron
Irons are generally not worth repairing. That said, try to clean out any mineral deposits with a mixture of 1/3 vinegar and 2/3 water. Put in the usual amount. Warm the iron, try to get steam. Empty the iron and do it twice more. Then, rinse it out with plain water.
You may get lucky!
Posted on Jan 23, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Posted on Oct 16, 2009
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
Filter light flashing what do I need to do no manual available
Breville VIN170 Extreme Steam Digital Steam Generator Iron
unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Tefal Gv8110 Steam Generator Iron no Steam
follow this steps. God bless you
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 10, 2012 | Irons
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 24, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Have just bought kenwood steam generator iron but there are no instructions with it. the filter light is flashing what do i do
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Aug 31, 2009 | Irons
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
I have bought a swan s15040n steam generator iron and it does turn on but I can't get to generate any steam. I have tried holding the steam button down for 20 seconds ( and more) but still nothing. Any...
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
Jul 13, 2009 | Black & Decker Steam Generator SG200 Iron
Irons Logo
91 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
