Question about Canon Office Equipment & Supplies
How do i replace a waste toner box for the canon color imagerunner c5185i
Canon color imagerunner c5185i
muleskinner2
  • 270 Answers
SOURCE: having trouble replacing waste toner receptacle on Canon imageRunner 3750
If the copier indicated to empty the waste toner you will have to reset in the counter in service mode. Press the additional functions key, the 2 & 8 keys at the same time, then the additional function key again. This should get you into service mode. If not depress the reset key and try again. Once there at the top right you will see counter. Depress it then you should see a menu and depress MISC. Depress WST-TNR, then depress "C" on keypad. Counter should go to all 0's. I think that the waste toner message displays at 250,000 copies made.
Posted on Feb 12, 2008
spinal
  • 287 Answers
SOURCE: Waste toner dumping
Hello lb. I promise you I can help you. I could go into overwhelming detail as to the reasons your copier has indicated to you that the waste toner bottle needs attention. I say this because your device can be programmed to either physically "look" at the condition of the waste toner container, or the device can use internal counters that are usual quite accurate. Since these "counters" reflect the wear on the drum (important s*&^%) they can be extremely cost effective as it considers YOUR usage compared to the average joe. My point is, the waste toner area of your machine was never truly meant to be dumped as it is a part of a cartridge. It can be done but odds of total success are not good and we still are looking at significant wear on other major components waiting to give you grief soon. A drum unit for your machine consists of a huge number of critical items and is good for about 20,000 copies. It costs +/- $100. Far less than a service call, and the drum gets replaced,again many other components, and the waste toner. Or you can remove the drum/development unit, find the semi clear plastic plug and remove it,vacuum it out or pour it out. Locate the the photo sensor inside this non-serviceable unit and clean it with canned air as you stand ouside and face away from the wind. Hmmmmmmmmm. I am not being a smartass, just trying to minimize your out of pocket costs and frustration. Good luck and take care. ........................SPINAL
Posted on Feb 14, 2008
checkitright
  • 1362 Answers
SOURCE: Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
Posted on Sep 08, 2008
  • 153 Answers
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
Posted on Jun 01, 2009
iservice
  • 318 Answers
SOURCE: I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Posted on Jun 17, 2009
Black copies are coming out faded. How do I fix this? I have already changed the toner and the waste toner bucket.
Does this happen when you print? Not Copy. Does the internal prints come out OK configuration page, meter count, etc.? Did you change the drum unit? Or is the drum unit and toner cartridge one in the same, drum would be blue or green, puts the image on the paper so be careful to not touch it. waste bucket really not a player in this situation.
Nov 18, 2015 | Canon imageRUNNER C5185i Touch Panel...
Waster toner box to be replaced warning on a konica minolta C360, the warning doesnt go even after emptying the box, the warning still appears.
in waste toner box plastic transparent tube is there open that and clean and blow air through whole container and try it
beacause that plastic cap told machine there is waste toner is present or not
Aug 16, 2013 | Canon imageRUNNER C2550 Color Copier
After cleaning waste toner container still showing waste toner full i cleaned the bottle and sensor path (transparent) error cleared and still showing wast toner box full
Did you clean the actually sensors in the copier it self???? Where the bottle goes in to place??? Try that and make sure the clear plastic is clean and turn the main power switch off then back on. Good Luck
May 04, 2013 | Canon imageRUNNER iR C2880 Color Copier
Replace waste toner 9060
actually you must reset the waste toner counter by enter the service mode
Nov 05, 2011 | Canon imageRUNNER 5570 Copier
E00013-000 ir3170ci
this is error for waste toner full detection.
So, you need to empty the waste toner box. It is located in front side of copier, beneath the copier cover, right side of toner inlets. To reach it you need to remove plastic cover above the box.
For service manual emma.servis@gmail.com
Hope that helps!
Aug 24, 2011 | Canon imageRUNNER C3170U Color Copier
I need to reset the waste toner until I receive a replacement for my ImageRunner C5051, is that possible?
This is incorrect. You can manually empty the waste. Make sure you remove the small clear plastic part that is on the side and empty it as well (this is what the sensor looks at to tell the macine it is full)
Sep 23, 2010 | Canon imageRUNNER 5570 Copier
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
Jan 10, 2008 | Baby Gear
18 people viewed this question
old marine
old marine
