Question about Black & Decker Food Mixers
REPLACEMENT BEATERS FOR CAMFIELD POWER MIX
CAMFIELD BY DORMEYER CORP. CHICAGO, ILL MODEL NUMBER 70 SM 6 CH 10 SPEED POWER MIXER SERIAL NUMBER 6404
  • 274 Answers
SOURCE: Replacement beaters for hand mixer
Black and Decker now has several store outlets all over the country. They are even online. You can order directly from them. 1-800-544-6986
Posted on Jul 15, 2007
  • 3 Answers
SOURCE: replacement beaters
See solution for Euro-Pro EP546 replacement beaters. Call them at 800-798-7398.
Posted on Feb 06, 2008
  • 3 Answers
SOURCE: Bravetti hand mixer beaters
Call Bravetti (Euro-Pro) at 800-798-7398 to order replacemnt beaters for $7.95 plus $4.95 S&H. All you need is the model #.
  • 20 Answers
SOURCE: Replacement beaters for Hamilton Beach Hand/Stand Mixer Model 64586
Call the factory. they will point you in the right direction. number online!
Posted on Apr 11, 2008
jerryg50
  • 1689 Answers
SOURCE: lost beaters
Toastmaster factory parts
http://abtecparts.com/toastmaster.htm
Jerry G.
Posted on May 29, 2008
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
How to disassemble Dormeyer mixer, Model 4300, to get to the motor?
how do you remove the power cord on dormeyer model 4300 mixer
Dec 05, 2011 | Food Mixers
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 21, 2009 | KitchenAid Food Mixers
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
Top Black & Decker Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Black & Decker Food Mixer Expert? Answer questions, earn points and help others
