Question about Panasonic Viera TH-42PX80U Plasma TV
Connect a vizio vht510 sound bar to panasonic th-42px50u
Optical output on tv to sound bar with optical cable ?
jscruggs420
  • 36 Answers
SOURCE: Panasonic TH 42PX50U Red power light flashes 6 times
Most of the time when this happens it is the ysus board, that noise you heard was a capacitor popping. Another board runs about $175 and thats if you do it your self. A shop will most likely charge around 500-600, hope this helps, you could also try contacting panasonic and trying to get past the tech and onto casemanagement where you might get somewhere with an out of warranty fix.
Posted on Feb 07, 2009
  • 21 Answers
SOURCE: TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Posted on Mar 11, 2009
  • 3 Answers
SOURCE: My panasonic is not coming on,the power button is
Count how many times it blinks. Sometimes the problem is coded in the amount of times it blinks. If you see a distiction between blinks, say like 13 then a pause then back to 13 more blinks, google solutions for a 13 blink standby for your tv and you might be able to find the soultion.
Posted on Jun 14, 2010
  • 5387 Answers
SOURCE: How do I connect my
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Posted on Dec 26, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: I have an acer notebook
http://www.ehow.com/how_4867953_connect-tv-using-vga-cable.html
Posted on Dec 30, 2010
I have a 42 Insignia TV and a Vizio 3821 sound bar. I also have Dish Network Hopper on this TV. I have tried all sorts of hook ups, but still no sound. Help
Soundbar & TV connection issues...Please Help!! - TV - Audio
www.tomsguide.com/answers/id.../soundbar-connection-issues.html
Aug 5, 2013 - the tv does have an optical output according to the website, it may just look hidden because ... I am trying(without success) to connect a JBL SB100soundbar to a Samsung ... Since your sound bar has an optical in then problem solved. .... a b x TV. August 5, 2013 10:32:42 AM. something like this should do ...
How to Connect a Soundbar to TV audio - YouTube
? 3:19
https://www.youtube.com/watch?v=Z27WtBy4IUs
Nov 22, 2013 - Uploaded by All About Home Electronics.com
The issue is not how to plug the cables in, it's all color coded and easy. ... I have a Sanyo sound bar but it won't connect to my LGtv nor my ps4!
Amazon.com: Sound Bars
Jan 10, 2016 | Vizio Televison & Video
Tip
How to connect laptop to TV Panasonic TH-42PX50U
Hi,<br />i have TV Panasonic TH-42PX50U, but i don`t know how to connect it with laptop...<br /><span><span>Can I</span> <span>do it</span><span>?<br />because i bought cable and it doesn't works, when i connect they then on laptop is signal, but nothing happens on TV and laptop more... </span></span><span><span>I</span> <span>open the</span> <span>laptop</span> <span>program</span> <span>but</span> <span>there's</span> <span>no evidence to show... <br /><br />i hope somebody can help me!<br /></span></span>
on Dec 18, 2010 | Panasonic TCL42D2 42 in HDTVReady LCD TV
My TV does not have audio output. will this system still work on my TV?
An audio output may be available if your TV is connected to a TV service provider box. . If you use a box than check to see if there is an audio output available. This will by-pass the TV.
Last resort there is probably a 2.5 mm connection for headsets some where on your TV. You can use a 2.5 mm to White and Red RCA connector cable to connect TV to stereo
This would be a simple stereo connection with out surround..
Nov 21, 2015 | Vizio VHT510-B Refurbished 5.1 Surround...
HOW DO I SET UP panasonic th-l37310a to phillips htl2101a sound bar
The optical cable should work. It's possible your set requires you to select external speaker in menu for optical out to function. Hope this helps.
Feb 02, 2015 | Panasonic Televison & Video
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
How can I hook a vizio soundbar 2.0 to a Panasonic t.v. Model number tc-p42c1
TV's generally have optical / toslink connections for their digital audio output. I'm assuming the sound bar has a coax digital input, in which case you will need an adapter module. I have seen these on eBay for around $15.
Try searching: Optical Toslink Audio Converter to Digital S/PDIF Coax
Jan 22, 2014 | Panasonic TCP42C1 Plasma TV
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
Dec 26, 2010 | Panasonic Televison & Video
Does anyone have a panasonic TH-42PX50U Service Manual I could download?
www2.panasonic.com/consumer.../model.TH-42PX50U
www.nodevice.com/manual/.../panasonic/th.../get29233.html
www.panasonic.user-manuals.com/list-of-manuals-292-5104.html -
You can copy and paste any of these links into your address bar to bring you to your manual
Aug 25, 2009 | Televison & Video
Panasonic Viera TH-42PX80U Plasma TV Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
