Question about Philips BDP2900 Blu-ray Disc Player - 1080p
Firmware file ext BIN. for BDP 2900/12 on a USB is not accepted as proper file by the player
I want to upgrade Philips BDP2900 / 12 firmware version 2.46 to version 2.52. Downloaded the file and extracted the zip.file . Placed the Bin file on a USB and plugged it in the player. Message that the file was not a proper file cam back on the television
  • 3 Answers
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Posted on Sep 04, 2008
  • 78 Answers
SOURCE: i have downloaded driver for philips 170c monitor
These are the steps you need to follow to install the driver: Download from the link below:
Philips 170c Monitor
It is a zip file so you will need to unzip it into a separate folder. Once the files are unzipped you need to locate the 170C8.inf setup information file. Once you have located that file right click on it and you will see the option to Install. Click that and it will ask you to open it. Choose open.
If that fails you can do the following:
Installing a new device
1.Open Windows Device Manager. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
2.Once Device Manager looks ok reboot the computer.
3.As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
Posted on Nov 10, 2009
SOURCE: Philips DCP851 Portable DVD Player
We did that too and since the DVD portion was pretty much useless anyway, we 'bounced' the machine (lift the corner an inch or so and drop it) just a little where it was sitting and it finally gave up the discs. It seems to have been the death knoll for the DVD player, however. The tray will open and close but the machine won't always load the disc and play. Sometimes, it does, sometimes not. It also skips now sometimes, but not on every disc. It didn't bother the VCR portion, though. Our DVD player had been used A LOT so it might all be a coincidence that it's acting this way now, but I think putting the two discs in together damaged the inner workings (the bounce didn't help either but it was a loss anyway if it wouldn't open up) so it's up to you whether you want to risk this 'fix' or take it and have it repaired professionally.
Posted on Jan 23, 2010
guru_fixya
  • 944 Answers
SOURCE: I can't switch on my
Your firmware is corrupted so reinstall it.Just follow the steps given in the below link.\
Check out the Software & firmware section and update it.
http://www.p4c.philips.com/cgi-bin/dcbint/faqlist?ctn=HDD6330/17&dct=FAQ&slg=AEN&scy=US
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 04, 2011
  • 484 Answers
SOURCE: Getting an error message on
Here is a link where you find the user manual of your device:
http://download.p4c.philips.com/files/s/sa5295_02/sa5295_02_dfu_eng.pdf
Read it's content in the page 44. I think it is necessary to update of your player and I hope you can repair it this way.
gylacz
Posted on Mar 07, 2011
I have a Philips Home Theater model HTS3051BV/F7 C and I need to change for DVD region free or for DVD region 4, but I have not get procedure for this model. Can you help me please?
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Feb 14, 2011 | Philips HTS3051B/F7 Theater System
Tip
LG VX 9600 Versa Firmware Upgrade Follow these steps to reflash the firmware of...
Follow these steps to reflash the firmware of your Verizon LG VX9600 Versa Cell Phone to version 4.
  1. Install the LG Versa USB driver. Download and extract the first file "LGUSBModemDriver_Eng_WHQL_Ver_4.6.rar". Once extracted, install the file.
  2. Download the "DLLs.rar" file and extract it. Once extracted add the "Right_Click_Register_DLL.reg" to the registry.
  3. Install the LGNPST 1.1 software. Download this file, extract it, install it. REBOOT.
  4. Register the VX9600.dll file. Go to the directory "C:/LG Electronics/LGNPST/models/VX9600" and put the "VX9600.dll" and the "LGNPST_GenericModel_Ver_1_0_5_0.dll" files into that folder. (These files were in the "DLLs.rar" file.) Now, RIGHT CLICK on the "VX9600.dll" file and click "Register".
  5. Get the BIN file for version v04. Download it from here: LG-Versa-VX9600-v04-Firmware-Update and extract the VZW folder.
  6. Update your phone. Now plug in your phone and open up the LGNPST software. It should be under Programs ->Phone Flashing Applications -> LG Electronics. You should see your VX9600 under the "Model" column. Now where it says "BIN File" click the folder icon and navigate to the "VZW" folder with the bin file, then select it. You may also need to go to file -> Select DLL and select the "VX9600.dll" file, although I didn’t need to when I did it. Click start and your phone's firmware will be reflashed.
I hope that helps.
on Apr 21, 2010 | LG VX9600 Cell Phone
Menu screen keeps coming back while cable show is playing
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Print out the readme file the delete it off the USB Flash Drive
Make sure the USB Flash Drive has only one file on it (autorun.upg)
Then just follow the instructions from the "readme" file.
Fixed the "Menu" problem for me.....
Sep 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Netgear DG836GT
OK. First, that dg836gt_1_02_09.img file does not seem to be a firmware file. You need to get a .zip file or a .bin file to upgrade the firmware. Check Netgear's website for the current firmware. If it is a .zip file, then you need to extract the .bin file from the .zip file with winzip software. Then, log into your router with Internet Explorer by typing it the routers IP address in the address bar like this http://xxx.xxx.xxx.xxx. Enter user name and password. Look for a tab that states software update. Browse for the .bin file you downloaded or extracted from the .zip and click update.
Apr 25, 2009 | NetGear DG834 Router
My router reboots several times a day. Is this a known issue with this device when you have several devices connected over wired and the wireless? I have 1 PC wired. 3 PCs on wireless 1 Wii wireless 2...
Seems like this is a problem with this model, try the following: Upgrade the firmware of your router: ► you may find the exact model number and version number underneath the router itself on one of the stickers. If it's a WRT54G v5 upgrade the firmware, make sure the firmware version is 1.00.9 and above. To find the firmware version: ► open up internet explorer ► on the address bar type in the numbers 192.168.1.1 ( username just leave it blank, password as a default is admin) ► go to the status page: look for the firmware version To download the firmware: ► go to www.linksys.com/downloads ► search for your product model number and version the list ► click on downloads for this product ► firmware ► download firmware ► usually the file you download is a zip file so extract the contents 1st To upgrade the firmware: ► go back to the 192.168.1.1 page ► go to administration ► firmware upgrade ► browse for the files you extracted and use the file that ends with a us_code.bin ► and then just upgrade Then reset the router for 30 seconds and voila ur done with the upgrade! here is Linksys' 2nd level T/S phone# 18668705819 If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 11, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Green Power light flashing
Hi, Have you tried a hard reset? Your model has a small reset button at the rear between the Internet/WAN connection and one of the antennas (Press for 10 seconds +). Also flashing power led is an indicator of firmware problem which might have been caused by a failed firmware upgrade/update. Instruction on how to correct this problem is also included in the firmware upgrade/update. A more detailed instruction is in the User Manual. With regards to firmware update/upgrade , pls be reminded that firmware is very version specific. To locate the version number, you have to look underneath the unit and download the appropriate firmware from LinkSys website. (http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&packedargs=sku%3D1115416826220&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888126220B03&displaypage=download) The download is a zip file which you have to extract to a folder. The .bin file plus instructions as well as specific instructions on how to make the power led stop flashing. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Jul 28, 2007 | Linksys BEFW11S4 802.11b Wireless...
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Charter High-Speed Cable and the BEFW11S4 Version 4
To resolve this problem, you will need to upgrade your router's firmware. Click ftp://ftp.linksys.com/pub/network/befw11s4_v4_v1.50.14_code.bin and download the file to your Desktop or My Documents folder (the link is to v1.50.14 firmware code). Once the BIN file has been downloaded, follow these instructions to upgrade the router's firmware: NOTE: Before upgrading your router's firmware, please make sure that the procedure is being performed by a computer that is connected directly to the Router with an Ethernet cable and not a wirelessly connected computer. Accessing the Router's Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Upgrading the Router From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. Click on the Administration tab. 2. When the ?Administration? page loads, click on the Firmware Upgrade sub-tab. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. If the logo matches the image above ("Linksys"), follow these steps: 1. Click on the Help tab. 2. When the "Help" page loads, click on the Upgrade Firmware link. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. After completing the steps above, the router's firmware should be upgraded successfully.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
How to upgrade the firmware on a BEFW11S4
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity (wired and wireless) on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have. Make sure to select the correct router version as well, as firmware upgrades frequently vary by version. You can find your router version underneath your router after the model number. For example, ?BEFW11S4 ver. 2?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Upgrading firmware
Downloading the Firmware Step 1: Before downloading the firmware, make sure that your computer has an active Internet connection. If your computer is plugged directly into the router and cannot get online, disconnect your router and plug your computer directly into your cable or DSL modem. Step 2: Once you are able to get online, click here to go to the WRT54G Version 5 Download page. Step 3: Click Download to download the firmware file. Approx. file size (Zip file): 1.39 MB If you are using Windows XP Service Pack 2 (SP2) and Internet Explorer, you may see a 'Pop-up blocked' message in your browser Information Bar. If so, click the bar and select Temporarily Allow Pop-ups. Then, click the Download link again. Step 4: Click Save in the File Download dialog box that appears. Step 5: In the Save As dialog box, choose a location for the file (like the Desktop) and click Save. The wrt54gv5_fw_1[1].00.6_US_code.zip file will then be downloaded. When the download is complete, click Close if prompted. Step 6: Double-click on the wrt54gv5_fw_1[1].00.6_US_code.zip file and extract its contents to a single folder (or to the Desktop). NOTE: You will need to use a utility to open and extract files from the ZIP file archive. Popular software to use is WinZip®. For information on how to download WinZip®, visit the following website: http://www.winzip.com. You can also use the built-in unzipping features of Windows XP to unzip the contents from the archive. The following (3) files should be available: * wrt54gv5_fw_1.00.6_US_code.bin * Readme.txt * wrt54gv5_ver.txt Upgrading the Router's Firmware Step 1: Plug your computer directly into Port 1 on the back of the router. Step 2: Make sure that the router's power is plugged in. Step 3: Open Internet Explorer. Type http://192.168.1.1 into the Address Bar and press [Enter]. Step 4: You will be prompted to enter a username and a password. Leave the username field blank, and enter admin for the password. Then, press [Enter] or click OK. NOTE: If you are asked for the password again, the router's default password was changed. Try a common password that you might have changed it to. If are still unable to log in, hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. Then, try Steps 3 and 4 again. Step 5: When the router's web-based Setup page loads, click on the Administration tab. Step 6: On the Administration page, click on the Firmware Upgrade sub-tab. Step 7: On the Firmware Upgrade page, click Browse. Browse to the location where the firmware files were extracted, and select the wrt54gv5_fw_1.00.6_US_code file. When the file is selected, click Open. Step 8: Click the Upgrade button on the Firmware Upgrade page to start the upgrade. The upgrade will take a few minutes - please do not unplug the router's power cord or make any changes during this process. Step 9: When the upgrade has completed, the following message will appear: "Upgrade is successful. rebooting...." Completing the Firmware Upgrade Step 1: Close Internet Explorer. Step 2: Hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. This step will ensure that the new firmware loads properly! When you are finished... The firmware upgrade is now complete! You can now use the router's Setup Wizard CD to configure your Internet service and set up your wireless connections.
Feb 16, 2006 | Linksys (WRT54GC) Router
Philips BDP2900 Blu-ray Disc Player - 1080p Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
