Question about Nintendo Wii Console
Wii will not synchronize with tv
I have the AV cable properly plugged in, even tried buying a new one. All i get is the audio from the wii, but no video, cannot see anything on the screen. The system seems to be responding, as are the remotes, i can hear everything if i start to click around on the main menu, just can't see anything.
  • Joe
    Joe May 11, 2010
    Why dont you try checking the wires see if they are losse if they are tape can hold them in place
  • 132 Answers
Try a different input on your tv. Or try another device in the port youre using and see if its malfunctioning.
Posted on Jan 21, 2009
There are no connections for the red whits and yellow AV cable in the new smart TV can i eliminate this cable and use a USB cable in its place this is for a wii
The usb port in Wii is for input devices (i.e. external HDD, Wii keyboard etc.) and can't use it to output signal going to your TV , its only the AV cable supplied by wii you can use to connect to tv. If the TV has no RCA input (yellow, white & red connections) you can buy AV to HDMI adaptor or AV to VGA adaptor to connect your wii to your new tv model.
Sep 29, 2014 | Nintendo Wii Console
Wii does not show up on the tv screen
This problem is likely due to a problem with your AV cable. Try the steps below to get your Wii up and running.
  • Make sure the Wii is turned on and all cables are plugged in.
  • Unplug the AV cable from the T.V. (The AV cable has a red plug, a yellow plug, and a white plug.)
  • Plug the AV cable back into the television making sure that the red plug goes into the red socket, the yellow plug goes into the yellow socket, and the white plug goes into the white socket.
If problems continue try replacing your AV cable with a new one.
Jun 16, 2011 | Nintendo Wii Console
Dropped in snow green light comes on but nothing else does
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
Jan 24, 2011 | Nintendo DS Lite Console
I formatted my wii and it says must have a update from the shop channel if necessary, add wii points
Jan 22, 2011 | Nintendo Wii Console
My xbox 360 picher will not show on the tv how can i fix it and the conteroler will not stop blincking
Try this first
Same procedures for an xbox
then try
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
Jan 20, 2011 | Microsoft Xbox 360 Wireless Controller
Who to do set up for wii game
  1. The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well.
    • Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom.
    • Look for inputs marked Audio and Video IN.
    • Do NOT connect your system to anything marked OUT.
    • Don't see these inputs on your TV? Click here.
    1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console
  2. Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console.
  3. Insert the AC plug into a 120V AC wall outlet
  1. Plug the transformer into the wall outlet.
Jan 12, 2011 | Fisher PC-25R20 25" TV
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
I am repairing my friends Nintendo Wii. There is major static issues with the sound. She says the static comes from the TV. I am wondering if the issue is due to a bad AV cable or if it would or could be...
If it's coming from the AV cable, the white plug (AUDIO L) and the red plug (AUDIO R) are most likely not plugged in properly. Make sure both audio plugs are firmly plugged in. Like I said, if it's coming from the cable, this problably is what's wrong.
Feb 27, 2010 | Nintendo Wii Console
Wii come on but has no picture help
sounds realy silly but hace you tried pusshing the wires in the back of your tv a little harder also could you tell me does it have sound there are a few things to test if we start small
Oct 16, 2009 | Nintendo Wii Console
Wii Guitar Hero - No Guitar Sound
if the audio works for regular tv
check to see if the av cable is in properly
or if the red and white leads are plugged in
a470eb6.jpgRed and White leads
21fdb44.gifScart
Dec 17, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Nintendo Wii Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
