Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
My Dirt Devil Vibe steam cleaner model # CE6680V vibe will not spray solution
The hose adaption for stairs sprays but not cleaner itself
3 Suggested Answers
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
  • 1739 Answers
SOURCE: i dont have a manual for the dirt devil vibe
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Posted on Apr 18, 2011
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
What? I have a Dirt. Devil easy steam carpet shampooed model CE 6300 HD. It was working great and then just stopped spraying out cleanser/water! Is there a manual or does anyone know how fix this problem?
Hello! You may need to prime the trigger to get the solution to start flowing. To do this, recline the handle and pump the trigger about 30 times. Then, turn the cleaner on and hold the trigger in for 30 seconds. The solution should begin to dispense. Be sure you are only using the cleaning products specified for use with this unit. Hope this helps! If you still need assistance feel free to reach out to use here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
May 09, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
Hose gone on Dirt Devil DD2821 need replacement
http://www.espares.co.uk/part/vacuum-cleaners/dirt-devil/dd2821/p/1086/112/0/970655/478317/universal-flexible-clean-.html
This is the only hose "Dirt Devil" has listed for your model number.
Dec 12, 2009 | Dirt Devil Vacuums
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
Dirt devil vibe 088915v
Jan 16, 2009 | Dirt Devil Featherlight Bagless Upright...
I have a dirt devil steam cleaner. do I put the water in both containers or the one that is long, on the handle
okay if your have one that looks like that picture for it the water goes in the white tank on the handle piece, if the water is not spraying i'm guessing your hoses are clogged, as this sometimes happens if that is the case, run some lime away through it but don't spray the limeaway on your carpet it will eat it just use it to rinse it out and clear it
Dec 13, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
