Question about Sanyo DP32746 32 in. LCD Television
My Sanyo Tv (model dp327460 is Busted
Okay,so, I pressed the reset button on the remote , and now, whenever I turn it on, The entire screeen stays black, except for a small blue square, that reads "Connect all signals and antennas to jacks and terminals on the back of the tv, then press the channel up key. First I tried to hit the channel up key to see what would happen, and it started searching for channels, but didn't find any, so I had to start over. then I tried unplugging everything on the back, plugging it back in, then hitting the Channel Up key. Same thing. I even tried to hit the reset button again, but that did nothing either.
  • Anonymous Nov 07, 2008
    Same exact problem, I tried unplugging tv and turning back on, same thing, there is no apparent way to get out of it if you don't use the TV for the channels to watch material. I just use it for my gaming console so I have no TV jacks or antenna connected
  • Anonymous Nov 14, 2008
    I push the reset button and my sceen is black nothing comes out. What can I do to make it work again
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
Posted on Aug 10, 2007
SOURCE:
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Default code for Sanyo GXDB remote for Sanyo TV
for sanyo tv....
1) press tv button
2) press and hold setup button till light blinks twice
3) enter code 10154 light blinks twice tv should work
Mar 31, 2012 | Sanyo 42 in. LCD TV
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Need the code for a sanyo tv to use a philips universal remote
Hello
Universal remote code to be cheked with Philips CL034 model remote habset to Sanyo are;
0506 0311 0612 0002
0428 0802 0412 0619
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power control switch each time before trying an other code.
OK.
Feb 16, 2011 | Philips Televison & Video
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Jan 25, 2011 | Televison & Video
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
Nov 25, 2010 | Sansui Televison & Video
I can't get my directv Remote to work my sanyo tv must use tv remte now to turn on tv and addjust volume
try these steps.
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code.
if your tv is not working the remote dont have your tv model stored, you need to find a compatible remote.
Feb 20, 2010 | GE JASRM24912 Remote Control
Programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Mar 11, 2009 | RCA RCR450 Remote Control
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Reprograming my tv remote
Hi chevry,
universal remotes vary with respect to button options. For a Sanyo TV you can try these codes. (This is manual mode).
0098, 0066, 0091, 0023, 0017, 0027, 0080.
Press the TV button on the remote. Than press & hold the set button until the LED stays on. Enter the four-digit code. When the remote control recognizes the correct code the LED will turn off. If the code is not correct the LED will flash several times & stay lit. Enter the next code. (You'll have less than 25 seconds to try another code) or the remote will exit the programming mode.
How to use the auto search. (One code at a time). This will take some time.
Turn on the TV. Press & hold the set button until the LED comes on, point the remote at the TV & press the volume + once (This moves the remote through 1 code at a time. Continue to press the volume + (Do not do this very fast or you'll miss the correct code), until the TV turns off or changes channel. Than press the set button again & the LED will go off. The remote should now be programmed for the TV. Test TV by turning the on/off button on remote. Check volume up & down.
Good Luck!
Mike
Jul 04, 2008 | Televison & Video
Sanyo DP32746 32 in. LCD Television Logo
367 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
