Question about Apple Computer Apple Bretford PowerSync Cart for iPad H3635LLA Mac Desktop
I have 1/3 of the PowerSync Cart that is not working. Is there an easy fix for this problem? I tried reaching behind to make sure all were plugged in correctly.
2 Suggested Answers
damien729
  • 221 Answers
SOURCE: drawer 2 doesn't sink
Hi Melinda, I may be too late, but if not, is there an error message while trying to sync?thanks Damien
Posted on Nov 20, 2011
200 pontiac bonneville how to install back three adelco spark plugs
Sorry no easy fix . make sure engine is cold hasn't run for 8 to ten hours than reach behind from side I personally think their is more room on drivers side behind engine remove plug wire one at a time and replace plug. don't forget to gap the plug so you don't have to do it again soon.
Oct 14, 2014 | Cars & Trucks
Price of cheaper priced ipads
Could you be more specific. Taking a wild guess if you are looking at for a cheaper priced iPad then Apples own refurbished site is a great place to start. Ebay is another place if you want to sample the used market. As a precaution make sure you get a model with enough storage, 16gb IMO is too small, a few books, a game or three and some songs and now you're stuck with not enuff storage and no means to upgrade without buying another model.
Sep 01, 2014 | Apple Computer Apple Bretford PowerSync...
Motor runs but cart won't go
1 check and clean fuel tank and lines
2 clear air filter, soapy water air dry then apply any air cleaner oil
3 adjust carb / chock
4 check for proper spark replace plug (2.99 )
5 make sure drive belt in good working order.
odds are the carb chock should fix you right up
May 23, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Hp 470 printer prints blank pages after replacing ink cart and reinstalling drivers and can't get the wireless feature to work
--Try to remove the cartridges
--closing the door
--unplug the printer
--plug the printer in
--when the printer powers on it will acknowledge the missing cartridges
--then put in the carts
See if the alignment page prints out with colour.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 24, 2013 | Office Equipment & Supplies
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
Drawer 2 doesn't sink
Don't really know the hardware, all I can suggest is since you have managed to sync one ipad have you tried one ipod. The standard response for something that has many potential factors causing a problem is to try syncing each one of the ipods separately, you could find that one of the ipods is causing the whole lot to fail. It will take some time to do but if it is just the one ipod causing it you can remove it and then try syncing the rest. Hope this makes sense?
The other thing is are all the ipods running the same version of the iOS, I saw from the user guide of the Cart that you need to deselect the check for new software updates automatically, could it be that one of the ipods is running iOS 3 and the rest are running iOS 5. You can check this under settings then general and then about and then version.
Hope this helps.
Nov 14, 2011 | Apple Computer Apple Bretford PowerSync...
How do you replace spark plugs 1-2 and 3.
  • The Vulcan engine (12 valve) are done real easy by going behind the engine on the drivers side and just reaching through.
  • If you have the 24 valve engine the it is easiest to remove the upper intake manifold and get to them that way.
  • It is possible to do without removing the intake manifold but if you have big forarms like me you will loose some skin. For this you remove the ignition coil (that's threee 10mm bolts). After this you need some extentions to reach over and back behind the engine to reach the plugs. Also make sure to suport the manifold when you unbolt it. If you have a bungie style cord laying around, that's what I use.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 10, 2011 | 2002 Ford Taurus
Apple Computer Apple Bretford PowerSync Cart for iPad H3635LLA Mac Desktop Logo
56 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
