Question about Homelite Garden
Homelite ranger tighten chain - Homelite Garden
  • 323 Answers
SOURCE: The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Posted on Jun 08, 2009
  • 71 Answers
SOURCE: I have a Homelite Ranger 16
It's probably the chain brake not disengaging. If you are handy you can remove the clutch guard and spray some WD-40 around the chain brake (avoiding the clutch with the lubricant) and move the chain brake mechanism back and forth a couple times and see if it releases. If not, take it to a qualified mechanic.
Posted on Jul 23, 2009
  • 7 Answers
SOURCE: how do I replace the primer bulb on a Homelite
Most of them snap in, meaning there are two small blades that are cast into the plastic for the primer bulb housing. These tabs fit into a recess and lock when pushed in from the outside. You will need the entire replacement as you cannot just replace the bulb like is possible on a Zama or Walbro carb. Whatever you do, make sure you mark the routing of the hoses. Its always fun to get them hoses mixed up and then wonder how theyre supposed to route...
Posted on Aug 31, 2009
Testimonial: "thanks for the advice, very helpful! "
dontbother10
  • 2220 Answers
SOURCE: jambed brake
Hello Brian; Why do you want to? You may never get it back together. The IPL is probably as good an illustration as you will find. Enlarge it enough to make the detail visible. There is a chain brake kit available that might include some instructions but no promises (brake dragging? try changing the clutch bearing). This is as detailed as it gets. Contact Homelite and they will likely tell you to take to a service center.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here. cursor down to "Ranger 33cc 16" Chain Saw UT-10926". "Clutch - Hand Guard - Drive Case Cover" detail.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 03, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: what is the oil and
easy use synthetic 2 stroke oil ,one uint of it does a gallon.. i use it on all of my 2 stroke toys.. and less smoke and no fouling.. its the nut !..
hey if'n i was of help tell me. BUY PRODUCTS MADE IN THE GOOD OLD USA.. TBHANKS Jay
Posted on Sep 12, 2010
Homelite Problems
make sure the holes on the bar are clean if they are fill with so-dust the oil will not pass inside of the bar
Oct 26, 2013 | Garden
Is there a replacement part other than plastic for clutch
you could either use an organic rubber type simelare to platsiic and do it urself - size etc
Apr 17, 2012 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Homelite gas chain saw 3316C How do I tighten the chain?
Lossen the bar and pull it out to adjust the chain tension
Jun 16, 2011 | Homelite Garden
HOW DO YOU ADJUST TENSION ON CHAIN FOR HOMELITE UT10519
Turn the tightener till the chain in the center of the bar at the bottom just hangs down about a 1/8"....
this will be good... too tight and the chain will not turn...too loose and it will come off...
that 1/8" is usually great for any saw...
heatman101
Mar 19, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
What is the oil and gas ratio for a homelite ranger gas chain saw?
Sep 12, 2010 | Homelite ZR10926 16 Chain Saw
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Homelite ZR10926 16 Chain Saw
Jambed brake
Lou
Apr 03, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Where can i buy a replacement chain for the expand-it prunner emmanuel1942@yahoo.com
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Mar 26, 2010 | Homelite Expand - It 10" Pruner Attachment
Spark plug gap on homelite 16 inch ranger chainshaw
I don't have access to an Operator's Manual and they don't appear to be available on line, I checked several different Homelite models at Chain Saw Collectors Corner. All said 0.025". HTH
Lou
Oct 11, 2009 | Homelite Garden
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
