Question about Jensen JP1500 Main / Stereo Speaker
Receiver I recently purchased a new receiver because the old one -- not that old -- would turn off when I played the CD's loud. Now, within a couple of minutes, the new receiver is also turning off. I have replaced the speaker wires with the best, and don't know what else I can do. I even had the new receiver checked out -- there is nothing wrong with it. What is the problem?
You are over driving both your amp and the speakers.
do y9ou have speakers in parallel-- making the combined speakers less than 4 homs? also the cd is probably rated with ( i for got he initials it something like CDX whish has a 30 hertz base boom to it this is a good caution to observe becaus you may be overdriving both the speakers doing damage ( this becomes a DC component and is generating a lot of heat energy causing your amp to clip ( overheat) and the speaker to stop in mid stroke causing mechanical damage).
Get a bigger amp. Starts.
Get a balanced System
Go to a rock concert instead.
work at a jet engine factory.
Good luck
Call me im a doctor you will soon need new ear drums.
Posted on Jan 09, 2008
SOURCE:
CD player makes crazy, loud sound while playing. Is this fixable?
Yes, it is probably fixable but not within the cost structure of the Crosley product. On the unit I worked on, the item looks pretty much throw away by it's construction. I just worked on one recently for my aunt. I am sure the cost to repait one of these would exceed it's value.
If you are in Chicago and want me to look at it- [email protected]
Dec 05, 2012 | Crosley Audio Players & Recorders
I have a cda 9884 and i recently purchased a kce-236b cable to connect my mp3 players to. I cannot get this to work. what am i doing wrong?
If you have connected the new cable correctly , and you have the system turned OFF... plug the MP3 player in and then turn the system ON ... it should recognise the new equiptment... and allow you to play the MP3 player.
Oct 06, 2010 | Alpine CDA-9884 Car CD/ MP3 Player
Pioneer cd player in truck stopped working
The lens is all worn out. It has reached its end of life. Time to replace the cd player... or if you can find a replacement lens. you can still use that player.. its an old player though, there are lots of new technology with the new players on the market.. its better to just get yourself a new one =)
Jun 21, 2009 | Pioneer DEH-2800MP CD Player
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Unit increases loudness on own
This has happed to me on several occasions. Try replacing the remote's batteries. That solved it every time.
Apr 10, 2009 | Harman Kardon AVR 320 Receiver
No sound using digital coaxial connections
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
May 16, 2008 | Yamaha HTR-6080
JVC KD-MK66 12 DISC CD CHANGER WITH ERROR
try a new batt in the remote as it colud be flat?
Mar 15, 2008 | Car Audio & Video
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
Loud humming on my tv and dvr with ny nad 761
The problem is the capacitor on the DSP board C107 2200mf / 16 Volts. Try replacing it and it should be fine
Oct 25, 2007 | NAD T761 Receiver
New receiver....old CD, record and tape players
Most new recievers don't have a "phono" input. If your record player is an older kind without a built in preamp, you will need to purchase a Phono pre-amp (about $25) and then you can use any input you wish.
Sep 13, 2007 | Onkyo TX-SR304 Receiver
Jensen JP1500 Main / Stereo Speaker Logo
163 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
