Question about ATI RADEON X1650 Graphic Card
I hav bought a new Ati 1650 Pro 512 mb Agp card. My problem is that when I insert the card and turn on the pc,it gives beep at regular intervals and the processors  dont turn on.I have core to quad with two processors both 2.80 GHZ.PlZ help me!!!!!!!!!!
  • Art Ellison
    Art Ellison May 11, 2010
    Please describe the beeps--for instance, just like the old Morse code, are the beeps something like 2 short and 1 long. The beeps will be something like that and then there will be a pause and the pattern will repeat.
    I would help to know the type of motherboard, too, and if there was an AGP card in use before or were you using something else.
  • Thomas F. Schneider May 11, 2010
    I have been readign the specifications of the board and  have a few questions,if you don't mind. The first is:
       Does this card have a place to hook up voltage from the power supply and have you done so.
       You have installed the software for thhs card and removed the old software, or turned off the onboard graphics.
      YO have upgrade your power supply and know that it has at least 10% to 20% reserve wattage,
    more that all of you parts consume. Thanks .
    Genius:
  • 1,102 Answers
Did you make sure this card is compatible with your system
you need to disable the old card
you can remove the new one start your system then disable the old one in devices
then use the new card install any software
Posted on Jan 21, 2009
Display is fuzzy with barcode like images across the screen at regular intervals.
Video corruption caused by a failed video memory chip. There's nothing that can be done to save it, the card is dead, replace it.
Jan 08, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
Looking to upgrade my graphic card one last time. Currently running a RADEON X850 AGP 8x. Dell XPS, 3 GHz Pent4 w/875P chipset.(800MHz Bus Clock, 400MHz DDR, Hyper-threaded (2)-- I would like the highest...
I wouldnt know whether you just like ATI Graphics cards, or it was recommended for you. But I would still give you my straight forward advice, and this is : Go for NVIDIA Ge-FORCE graphics cards. Trust me, you would thank me for it later.
I didnt want to recommend a specific model for you though, because of our difference in country locations, but just try and get a high memory (like 256MB and above), NVidia Graphics card that is compatible with your system. Also check out the available slot on your system that you will use for it first before you go (So that you wont go and get an AGP slot card when you have just an open PCI Slot). I'm telling you this because I've used A LOT of graphics cards also (Over 10 years now)! and I've come to that conclusion that NVIDIA makes the best graphics card.
Hope this helps you out.
Jul 15, 2009 | ATI AGP8X (128 MB) Graphic Card
Hi this is vinit...i'm planning to buy new graphic crd. plz adv..
This motherboard will support any PCI-Express (also known as PCI-E or PCI-X) video card-- which is pretty much any current ATI card that's out there. You DON'T want an AGP card however-- it won't fit.
Jul 02, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Can not start acer veriton 5600g with ati 1650 pro agp card ? The bios doesn't seem to recognise the card and it beeps when i disconnect the onboard vga. Any help will be appreciated... thanks
How did you disconnect the onboard VGA?
The onboard VGA device must be disabled in the BIOS and the ATI graphics card inserted in the computer.
When you bootup it should default to a standard Windows VGA configuration, then install the ATI video driver o you can get high resolution graphics.
Jun 24, 2009 | Acer Veriton 5600G PC Desktop
One long beep tow short beep
One long beep and two short beeps mean faulty video adapter.
If you are using a card, like a PCI or AGP video adapter then remove and put back the card in slot.
If you have a motherboard, then the video chipset on motherboard had gone, buy an agp video adapter and insert it in the slot inside your computer to fix the problem.
below an example of PCI and AGP video card:
MSI G4MX4000-T64 64 MB Graphics Card
HP Intel DVI AGP digital display card
ATI Rage 128 Pro 32 MB PCI Graphics Card
Mar 09, 2009 | Computers & Internet
AGP card not suport to play games
Only solution is to upgrade your video card. ATI Radeon 1650 pro 512 mb card is available in an agp format. This card is probably the best out there for an agp board. All you would need to do is purchase the new card, remove old card, insert new, reboot & use the cd that comes with the new card to install drivers. Hope this helps & please rate my answer fixya. Thanks.
Feb 03, 2009 | Dell /nVidia Ti4200 GeForce4 64MB w/TV Out...
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
My hardware upgrade
all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
Mar 18, 2008 | Computers & Internet
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
ATI RADEON X1650 Graphic Card Logo
63 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
