Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I have a coleman/evcon electric ignition lp furnace. I get error cede combustion air switch stuck closed even after replacing the combustion air switch.
    New Friend:
  • 70 Answers
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Evcon, 3 flashes, combustion air switrch failed to
I have 2 of these furnaces in mobile homes I own. On both of these the wheel inside the draft inducer blower that has the clear tube attached to it has a small wheel in it that over time tends to stick. Take the 4 screws out and give this little wheel located towards the bottom a push. Your problem may be solved without investing in expensive parts :)
Jan 26, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon furnace that wont work. The electrical box green light is not on at all so it cannot pinpoint what the error is. Any thoughts?
Hi, I would just make sure you have power to the furnace. Check breakers or look for the power switch on the electrical box. Also, some mobile homes have a wall switch that cuts power to the furnace.
Jan 16, 2010 | Coleman Propane Forced Air Heater...
I have a coleman unit the heater quit working. There is a red light that blinks three times. It represents ignition lockout. How do I fix it
Pressure switch error code, check air filter, condenstate drain and hoses, check for vent blockage, check for low spots in the venting holding water.
Dec 25, 2009 | Coleman Propane Forced Air Heater...
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
621 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
