No remote. Turns on automatically when plugged in, but the buttons don't work on the monitor. Tried the reset button on the back of the tv but it seems to do nothing.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
SOURCE: My New LG LED TV
you can down load your manual from this link, i did notice that your product number is not listed in full or has been removed . if you add 00 at the end you will still be able to receive a manuel with instrustions for the remote and resetting.
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
