Question about Magimix 5100 Cuisine Systeme Food Processor
Magimix pulse button sticking, how do I clean it
When we press the pulse button on our Magimix it is beginning to stick and make it hard to turn off. Is there a way to clean it?
magimixman
  • 11 Answers
SOURCE: magimix sytem cuisine
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Posted on Aug 31, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magimix Cusine System
Here is the generic English Magimix manual - it covers a lot of different model numbers. The good news about this manual is that it is picture-intensive instead of word-intensive. The key is that every piece of the bowl must be in the correct position, or the food processor won't tunr on. Hope it helps:
http://www.magimix.com/upload/usa/download.pdf
-Tha mp3 Doctor
Posted on Mar 12, 2009
SOURCE: Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Posted on Jul 04, 2009
ailia
  • 175 Answers
SOURCE: im looking for the user manual for a magimix 3100
Try to visit THIS link, hope this will help u.
Regards;
Hasan
Posted on Dec 27, 2009
Testimonial: "thank you"
caroldon
  • 17130 Answers
SOURCE: dead motor in Magimix Cuisine 5100
Remove and check if there is any fault of a brush contact or switch contact or if the load trip switch had reset.
If the power is coming to the motor and is not running you need to confirm fully if the windings are open , if so replace motor.
if not remove and reset the setting of the brush/commutator.
Posted on Sep 24, 2010
Testimonial: "A good simple test to perform, and optimism about a solution either way - thanks very much!"
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
What tool is needed to undo the four screws below the Magimix. I need to remove and clean the buttons which won't depress and sticky due to an overflow of mixture. Thank you
you did not described the screw or model of your machine, most of them use "secure" screw system of various shape, you need to check what shape is your particular screw and then go to closest hardware store and buy set containing that particular screw,
magimix use mostly torx screws, but you need to check as this vary from country to country... just to make our life more difficult...
Feb 08, 2015 | Magimix Food Processors
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
I just bought a new 3200xl magimix and it not working
I had this problem. I fixed it by turning the bowl to face the opposite way.
There is a little plastic button - the handle has to be over this.
Jun 11, 2012 | Magimix 3200 Food Processor
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
Magimix 3500 motor or switch problem?
Hi, answer came up on howtomendit.com. It needs new PCB.
Nov 02, 2009 | Food Processors
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Need to fit new switch assembly
Only two screws ?? this must be an older magimix 5000 machine, does the replacement part have a 10mm frame around or flush, the part you need is click here http://www.magimix-spares.co.uk/On-Off-Pulse-switch-with-frame-5000---5100-Chrome/product/101296/
Sep 15, 2008 | Magimix 5150 Food Processor
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix 5100 Cuisine Systeme Food Processor Logo
228 people viewed this question
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
