Question about Mintek DTV-373-D 37 in. LCD HDTV
No sound TV was working fine...with sound. Paused the TV for about 5 minutes and, when I hit the Fast Forward button to catch up to real time the sound went out. The other TV (not HD) that is hooked up to the same box still has sound.
    Brigadier General:
  • 5,158 Answers
Check to make sure you haven't hit mute in error
Posted on Jan 20, 2009
Installing ps3 to u-verse
You will want to hold the key of whatever option you are programming (ie tv, aux) and the ok button when you let go the button you held will flash once or twice. Each time you hit the fast forward button the remote will cycle through a code. Keep hitting the fast forward button until your device turns off, then hit okay again.
Dec 23, 2014 | Sony Playstation 3 (PS3) Console
On my Zen V Plus, I have an audio book that is sectioned into 8 different parts, each 1 hour in length. When playing one of the sections, it is registered as being 5 minutes 45 seconds in length, but still...
The unit only displays time allotments up to 59 minutes 59 seconds and then turns over. In other words, a file that's 1 hour and 6 minutes will show up as you have seen, 00:06:00 instead of 01:06:00.
The time on the bottom left is time played while the time on the bottom right is time remaining. Your unit will work fine once you get the hang of knowing how to look at the timers.
Sounds like you're listening to Podcast's.
Note 1: Now Playing - If you shut the unit down while it's playing your selection (it can be paused too), when you power back up, you can simply pick up where you left off by choosing "Now Playing" or just wait for the unit to automatically start the last file where it left off. Either way, it will start where you left off. This only works for the last mp3 you were listening to.
Note 2: Different File Time Reference - If you want to listen to another file other than the last one you listened to and you want to skip, say the intro and go directly to a specific area in the file, you will have had to remember a time reference from either time played or time remaining to get back there.
Note 3: Fast Forward/Rewind - As there's no bookmark feature on this player, the only thing you can do is to make a note of the time where you last left off of the mp3 and hold the stick/button to the right and fast forward to the general location. As you're scrolling to the general area, the longer you hold the stick/button, the fast forward progress will pick up speed to get you there quicker. Same holds true when going backwards.
Hope this helps.
Oct 15, 2010 | Creative Labs ZEN V Plus MP3 Player
Brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
Feb 18, 2009 | Brookstone SmartSet Alarm Clock
No vhs picture.
Jan 11, 2009 | Panasonic DMR-E75V DVD Player/VCR
Rewind and fast forward
Put the cd in when it loads and display the disc time, you can then spin the round wheels forward or backwards to the place on the song that you're playing, this only work when the song is paused or stopped. If the disc is playing the wheels are only used to slow down or speed up the song.
J Lofton(2Housepeople)
Oct 17, 2008 | Gem Sound CDM-150 Mixer
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Rca 61 inch projection tv model D61W20
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
Sound goes off after 5 minutes
hi there, yes it can be fixed, hitting the unit means that you have a cold solder on the board. the sound is in the amplifier section, check some connection at the speakers and amplifier, a cleanning and a reheat of cold solder to the baord is required. ty
Dec 14, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Mintek DTV-373-D 37 in. LCD HDTV Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
