Question about HP Pavilion Computers & Internet
The dvd drawer does not open
The pc turns open does not boot up and the dvd burner door does not open
    Master:
  • 965 Answers
Take Is it etting power? take the "master key" (paper clip) and open up the drive. put a cd in and see if the light comes on and tries to read the disk
Posted on May 16, 2014
3 Suggested Answers
jhull
  • 10 Answers
SOURCE: CD burner drawers wont open or close
sounds like a bad cd rom. as cheap as they are the best option is to replace.
Posted on Mar 20, 2009
danmats
  • 195 Answers
SOURCE: Installed a new dvd burner for Hp computer.
it has to do with a new hardware installation process....check IDE cable that they are correctly connected and try to check system setup so that the CMOS identifies both, primary & secondary devices....if not, u need to install a driver for the newly installed one....
Posted on Oct 05, 2009
Testimonial: "Sounds good. Have to try it tomorrow."
Dvd is jammed
If the DVD player/drive door or drawer will not open, try taking a regular metal paper clip, straightening it out, and inserting it into the small hole that releases the cover. Use a flashlight to look for this little hole, insert the paper clip straight in, and press firmly. The door/drawer should come open.
Oct 21, 2013 | Computers & Internet
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Problem with yamaha crw8424s...this device was working untill today...now the device has 2 flashing red lights, is no longer recognized, and drawer does not open or close. Any ideas or is this device shot...
Power off the PC, open the case, disconnect burner, power on pc, restart it, power off, reconnect burner, power on. If it work's then you're done. If no, ask your local computer story for a DVD burner
Nov 20, 2009 | Yamaha CRW 8424 Burner
Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Nov 11, 2008 | Philips PCRW (PCRW404) CD-RW Burner
Solid green light
Turn off the computer. There is a small hole underneath the drawer and above the eject button. Push hard into this hole with a long pin, or the blunt end of a long needle, and the drawer should pop open.
Aug 18, 2008 | ASUS DRW-2014L1T DVD-RAM Burner
Dvd/cd drawer will not open
Hi overeater,
With your system turned OFF and unplugged, look at the front of the drive, you will see a tiny hole to one side. Open up a paperclip, insert it into this hole and push gently. The door will pop open. Pull gently the rest of the way.
If this has been the first occurance of this, try just turning your system back on and allow the drawer to close on its own. Then try opening it the correct way again.
If the door fails to open again - most likely the belt for the drive is bad. DVD/CD drives are fairly inexpensive these days and would probably be best to replace it.
Jul 24, 2008 | Computers & Internet
Fix
ok restart the cdmix1 it ll work..
Jun 23, 2008 | Nu Mark Numark (CD2CD) CD-RW Burner
LG dvd video recorder
sounds like the belt is slipping.
is there a little hole in the unit? you can take a paper clip and straighten it out and poke it in there to force the door open.
Dec 12, 2007 | Zio Corporation (DM-3000) CD-RW Burner
Internal cd writer
yes, you will need to remove and open the rom up and re align the door to gear.
Nov 01, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
