Need eeprom file for epson r285
Basicly ive managed to change the printer to a r290via the adjusment program for the counter restter. My pc is reconising it as a new printer an wants new drivers etc. Hw can get it back to the r285 status? I was told i need the eeprom files for the epson r285 but cant find em anywhere
SOURCE: cant install epson c46 printer on vista
i've just installed the xp drivers which then vista told me they didn't work... but just plugged in printer and it works so not really sure why but i think just pluggin it in is good enough
Posted on Oct 30, 2007
SOURCE: ciss for epson r285 printer
Check the carts on the ciss the chip on the front will have the version number in the top left corner the latest version for all new R285 is I believe V5.0 if you have a version earlier than this you may have probs I believe its possible with a little care to buy some disposable compat carts and remove the chips and put them on your ciss carts this should solve the problem....Tel.
Posted on Jan 19, 2009
cene765
  • 787 Answers
SOURCE: r285
Look here: http://www.fixya.com/support/t3187141-same_problem_espon_r285_find_service
Posted on Oct 14, 2009
cns assoc
  • 677 Answers
SOURCE: Parts inside your printer are at the end of their
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Apr 05, 2010
  • 2666 Answers
SOURCE: epson 1280 on mac: I need to replace the ink waste
Still locked out until the counters are reset.
Posted on Dec 02, 2010
How do i reset epson r285 counter
Use Adjustment program for epson r285
Dec 14, 2013 | Office Equipment & Supplies
Eeprom epson 9800
To rewrite eeprom, you must having 9800 eeprom from printer that no problem at all. and Adjusment program for it. But, i think the problem is in the head, did you check the nozzle. How about the result? Is it perfect, and clearly? or is there any "dirty" around the lines?
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Ref my Epson R285 error message reads - parts inside your printer are at the end of their service life. How do you overcome this?
You replace the ink pad and then reset the printer so it works again. I know a place called pudsey computers www.pudseycomputers.co.uk that sells the pads or the do the whole thing for 30 odd quid. a program called SSC resets the counter which you can download off the internet, or your local epson express centre will reset the counter.
Oct 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Service life end
Care to read this link
http://tricks-collections.com/reset-epson-stylus-color-printers/
Just browse for the link of your printer model.
Sep 18, 2009 | Epson Stylus R290 InkJet Printer
Turn on Epson DX5000 printer and all lights flash and printer will not boot up - any suggestions
Need to reset waste ink counter/counter overflow. Use SSC or adjusment program for this type. Find at indoreset.blogspot.com
Jul 23, 2009 | Epson Office Equipment & Supplies
Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Martin
Jul 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Why does everyone go quiet when I mention Epson r285 , 2 red flashing lights and service needed. Does no-one of you highly intelligent boffins know how to reset a simple printer. Ive asked and asked on...
Bit late in replying but this guide for dealing with the R285 has been up for a while now.
It tackles everything from installing a waste ink tank to resetting the waste ink counter.
Wrote the thing myself following quite a bit of interest... Hope it helps.
Apr 06, 2009 | Epson Stylus 2200 InkJet Photo Printer
2 red lights flashing service required
press maintence power and the small ink button all at the same time this will reset the printer
Apr 05, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson r285
have an epson r 285 but cant findservice utility for resetting printer counter
Nov 13, 2008 | Epson Stylus Photo R220 InkJet Printer
49 people viewed this question
k24674
