Question about Epiphone Music
Replace Epiphone Elitist neck inlay
I am missing the 7th fret trapziod mop neck inlay on my Gibson Epiphone Elitist
  • 6 Answers
SOURCE: strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Posted on Nov 15, 2008
  • 161 Answers
SOURCE: which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Posted on Mar 23, 2009
Fenla
  • 51 Answers
SOURCE: great guitar, **** elrctronics. want to put '57 gibson classics
You wont need new tone caps and the wiring will not need to be replaced even if you are installing new pickups.
Posted on Apr 07, 2009
1fastbob
  • 301 Answers
SOURCE: truss rods and dead frets
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Posted on Oct 31, 2009
  • 417 Answers
SOURCE: my guitar has is an epiphone les paul but it also
Epiphone is a budget conscious gibson. And probably not made in the USA.
1957 - Gibson's parent company, CMI, buys Epiphone for $20,000, originally intending to harness its upright bass operation, but ultimately reviving the Epiphone name on guitars. A full line of newly designed acoustics and electrics is unveiled in 1958, and two years later Epiphone production moves into Gibson's factory in Kalamazoo, Michigan.
1970 - In the face of foreign competition, Epiphone production is moved to Japan. Through the 1970s and early '80s, the Epiphone line has little continuity, although it maintains respect as a quality import brand.
1983 - Epiphone production is moved to Korea.
1986 - Henry Juszkiewicz, David Berryman and Gary Zebrowski acquire Epiphone and Gibson. The Epi line is soon expanded to include traditional models like the Sheraton, Emperor and Howard Roberts, along with Epi versions of Gibson classics like the Les Paul, Flying V and Explorer.
http://www.epiphone.com/history.asp
Posted on May 27, 2010
I have a Gibson guitar that I would like to know the model name of.
if you contact Gibson with the serial nuer, they can tell you exactly what you have. Here's the link-
Contact Gibson Brands Inc
Mar 07, 2017 | Pearl Music
Epihone Gibson special serial number 16020609 any possibility of deciphering origins and year?
hi!
Thre serial doesn't seem to fit any of the common schemes. Please double check that it's correct, and see if there is a letter associated with it as well.
That said, the bolt on neck Epiphone Special instruments are made in China.
Sep 04, 2016 | Gibson Music
What wood and year ?
Neck Material: Mahogany- Neck Type: Artcore set-in- Body: Maple top/back/sides- Frets: Large frets- Fingerboard: Bound Rosewood- Inlay: Pearl dot inlay- Bridge: ART1 bridge- NeckPU: ACH-ST- BridgePU: ACH-ST- HW Color: CH- Width: Max width at lower bout: 15 3/4"- BodyThickness: Max body thickness: 3 5/8"
Your guitar was made at the
Sejan Plant, Korea
September 2014
Production Number: 120
Feb 24, 2015 | Guitar Research Music
I need a neck for a les paul *** wee. Where can I get one?
If you don't find one on Ebay, check local music stores for one that is a licensed Gibson dealer, and I'm sure they could get you one, or you can order one from Gibson.
Mar 14, 2014 | Epiphone Les Paul Pee Wee Rave Rig Guitar...
How to adjust truss rod on yamaha f335 guitar
Taken from http://www.learnguitarsetups.com
There are a few golden rules when adjusting your truss rod. First, only use the rod to keep your neck as straight as it needs to be...do not use it to adjust your action! Second, only use the proper tools. If you do not know what the proper tool is, check with the manufacturer. Truss rod nuts are easy to strip, and once they're stripped, they are expensive to fix! Finally, do not force anything; an eighth of a turn can make a drastic change. Remember, if the truss rod feels tight or doesn't seem to be doing anything, take it to a professional.
  1. Start by sitting with the guitar in the playing position.
  2. Tune it to pitch if it is not already.
  3. Capo the first fret. If you do not own a capo, you can use your fretting hand.
  4. Next, fret the bass string with your picking hand up near where the neck joins the body. This is typically around the 14th fret, but it may be higher up with some electric guitars. In our example, we'll be using the 20th fret.
  5. Use the string as a straightedge held against the neck which will either bow away, or against the string. This is how you determine the amount of relief in the neck. You can also use a steel ruler placed along the length of the neck, in the same manor.
  6. In our example, the approximate half way point between the 20th fret and the 1st, will be the 7th fret where we will observe the distance between the top of that fret and the bottom of the string (or ruler), as pictured. Notice the gap. Hint: Half way down the neck is often between the 7th-9th frets.
  7. If you have a gap between the top of the fret and the bottom of the string, you likely have a bowed neck. If there is no gap, it is likely either dead straight or back-bowed.
HOW MUCH TO ADJUSTThe bigger the gap, the more relief is in the neck. Normally, we want just a small amount of relief in the neck for optimal playing, about the same as the thickness of a business card or less.
If there is a gap, tighten the truss rod clockwise until you have something closer to what we're after. Slide a business card in between the top of fret and bottom of the string (or ruler). Make sure you are placing the card parallel with the string or ruler. If there is no gap, you may be either dead straight or back bowed, so you will need to loosen the truss rod counter-clockwise to get the results we are after. Hint: If the strings are buzzing in the first few frets and open strings, it is often a clear indication of a back bow.
Remember, do not force anything to get the results you are after. If it is hard to adjust or spins freely you may need professional assistance.
The final step in setting your relief is to test it out! If it feels better, you're done! But take note, straightening the neck may actually make your guitar play worse! Consequently, when the truss rod is tightened, the height of the strings are lowered, which can create string buzz if your guitar isn't setup properly to start. Likewise, it can make a poor fret condition more noticeable. So, if your guitar plays worse after adjusting the neck, it is either too straight for your playing style, or it is a sign that more work is needed. Thankfully, you can easily reverse the changes you've just made if required.
For pictures and further info, visit www.learnguitarsetups.com
Dec 16, 2012 | Yamaha Music
Epiphone sheraton 2 has broken neck tuner section
That is near fatal... you might find a Luthier that could repair it. I have repaired three broken neck instruments myself, an acoustic bass, acoustic hollow body, and a banjo... it is NOT fun and requires great care. The strains on the neck from string tension cause a lot of force that tries to re-break the neck.
Mar 15, 2011 | Epiphone Elitist Sheraton Electric Guitar
My guitar has is an epiphone les paul but it also says gibson directly above the nut. what does this mean?
May 27, 2010 | Epiphone Les Paul Studio Electric Guitar
Truss rods and dead frets- how do I adjust the guitar so the strings are close to the neck without getting dead frets?
Hope this helps.
Bob
Oct 31, 2009 | Epiphone Les Paul 100 Electric Guitar
Great guitar, **** elrctronics. want to put '57 gibson classics
Apr 07, 2009 | Epiphone Les Paul Studio Electric Guitar
Music Logo
26 people viewed this question
Top Epiphone Music Experts
Robert Graf
Vito Vacirca Jr.
dave nyman
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
