Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do I hook my 6110xi printer to the phone line.  There are 2 plugs and cords in the phone line.  One is going directly to my phone.  The other is plugged into the back of the modem.   There is no phone line plugged directly into the back of the printer.  Where would I connect it there, and then where would it connect it, seeing as the outlet in the wall already has the 2 plugs in it? When I look at "printers and faxes" on my computer, the fax info. is not there. I have Time Warner service with a wireless netgear box
  • Can You Help Me By Telling Me What Plugs Go In The Printer To Fax
Posted on Jan 21, 2009
Fax wont' go through. Plugged phone jack into phone line and when I try to fax it doesn't connect. Any suggestions? Thanks
Can you receive any faxes. Run a Fax Test from the Tools menu. Is the problem with only one fax receipient? (Check the phone number and make sure they are set to receive. I have dealt with one fax receipient where the call-waiting service caught the fax call.)
Does the Fax see a dial tone? If there is no dial tone, use a single line phone (corded) to listen for a dial tone at that jack. If there is no dial tone, check the incoming service for a dial tone. (If you have no dial tone at all, contact your service provider.) Try a new phone cable (2-wire RJ-11) Try calling the number from another phone line with the single line phone attached. If the phone doesn't ring with a new cable, check your wiring and then contact your provider. Is the signal analog or digital (the all-in-one is designed for digital)?
Go back through the fax settings and set it as directed in Step 2 here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612 . You need the fax error reporting setting.
Disconnect any items that are plugged into the 2-Ext port.
Try reinitializing the unit. Unplug the power cord with the unit on. Make sure that the phone cord is fully seated in the 1-Line port. Then reconnect the power cord.
Try resetting the all-in-one, this may require 2 people. With the printer on, unplug the power cord and wait at least 20 seconds. Press and hold # and 3 while plugging in the power cord. Release the buttons after the unit starts up.
If none of these steps help the unit may need service.
Jun 27, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Tip
How To Fix Your HP Fax Phone Off Hook
<ol> <li>If you don't know your product number, <a href="http://h20270.www2.hp.com/ediags/gmn2/welcome.aspx?lc=en&cc=us">click here</a> to automatically detect it.</li> <li>Manually download your drivers by <a href="http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us&lang=en&softwareitem=oj-40521-2&os=228">clicking here</a>. Enter your Printer Model Number, e.g. Deskjet D2680</li> <li>Unplug the power cord from the back of the printer and from the wall outlet. Reconnect the power cord to the wall outlet, but don't connect the power to the printer just yet.</li> <li>Perform a partial reset by disconnecting the power cord from the wall. Then, hold the # and 3 while reconnecting the power cord. Release the buttons once the cord is plugged in. When you release both buttons, the issue should be resolved.</li> <li>Perform a semi-full reset if the partial reset did not work by pressing and holding # and 6 while reconnecting the power cord to the printer and hold for 1 min after plugging in the power cord. When you release both buttons, the issue should be resolved.</li> <li>Verify that the phone cables are properly inserted into the wall jack and the back of the printer if you are receiving a "Phone off the hook" error message.</li> <li>A Phone Off Hook message indicates that the telephone line is open. This message would be expected in the following situations:</li></ol> <ul> <li>A modem on the phone line is accessing the Internet. When the other device is no longer using the phone line, the display should revert to the normal message.</li> <li>A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.</li> <li>A credit card machine is using the phone line.</li> <li>Another electronic device is using the phone line.</li> <li>Telephone Answering Machine using the phone line</li> <li>The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.</li></ul>Check this website for further help from HP: <a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125">http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125</a>
on Feb 22, 2011 | Office Equipment & Supplies
Fax Error 386, HP 6110xi Fax failed Is there a solution?
See http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
Too much noise on the phone line: e.g. bad connection, unshielded phone cable next to a electrical machine (motor!), temporary problems in phone service providers network.
Fax is essential data transmission by beeping noises. If crackling on the line or other disturbances degrade signal quality too much, the data cannot transmitted properly anymore.
Feb 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hooking up mx310 all in one
The phone line should plug directly into the Line plug on the DSL modem and the all-in-one should plug into the Phone plug next to it. If you need to split the line do it AFTER the line comes out of the Phone plug.
Feb 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Hp office jet 5610- can't print
Please check for any paper jam inside the machine, Phone off hook message is becoz if you use the same phone line for fax and telephone, thats normal. Follow the steps below,,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 22, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer will not align print cart.
hi,
Please check the following weblink and perform the instructions provided.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=79480
Once you are done with the instructions, perform the following steps:
Connect the All-in-One(Printer) directly to the walloutlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the steps below:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord
Regards,
Sagarjd
Nov 21, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
I have a hp officejet 6110xi all in one
hI,
the Issues seems to be with the hardware malfunction and it is not only related to the cartridge.
However, you can perform the following steps and in case if the issue persists, you need to replace your printer.
Connect your printer directly to the wall outlet.
2. Wait 30 seconds.
Regards,
sagarjd
Nov 18, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
Phone off hook error message
perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01832&cc=us&lc=en&dlc=en
May 22, 2008 | HP Officejet 6310 All-In-One InkJet...
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
