Question about Pride Health & Beauty
Pride battery charger will not charge why?
96ag e215551
  • Pride Master
  • 9,771 Answers
There is a fuse in the charger. The batteries bay be too far discharged so the charger cannot recharge them. The batteries may be too old . Poor connections at the battery posts. Check all these and somewhere you'll find the problem.
Posted on Feb 24, 2015
mcdevito75
  • 1970 Answers
SOURCE: batteries won't fully charge
mcdevito75 here, Sounds like the chargeing system has gone bad. Contact Pride online or phone.
Posted on Jun 29, 2010
  • 14 Answers
SOURCE: I just bought new batteries for my Pride Ultra Go
1.Make sure you installed them correctly.
2.Check the voltage on the batteries. If either (or both) register less than 11 volts, either return them for ones that have 12 volts, or attempt to bring them up to 12 volts with an automobile battery charger. Once brought up to 12 volts, install them, then make sure you recharge them with the supplied charger/adapter before or when the on-board indicator it shows low (red). If the battery voltage drops too low, the supplied charger simply won't even try to charge them.
Posted on Aug 20, 2010
  • 346 Answers
SOURCE: Hi. Our pride Ranger PMV
Hello Simon.Visit-www.alldatasheet.com its free.Download as a PDF File & save + if you choose print for future ref.To your Adobe Reader.Type in the correct boxes for a troubleshooter.Merry Xmas,any problem,please ask again,Colin.
Posted on Dec 16, 2010
  • 63 Answers
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Posted on Jan 17, 2011
Mustgo
  • 2359 Answers
SOURCE: My Pride Jazzy Jet 2
Are you comfortable working on the electronic cable / connector?
Check the temperature charger's by hand. It should be warm to the touch when power on.
Since you has the unit plug in for days,it should be warm to the touch.
You will need to has a volt meter to check the voltage output on PIN 1 and 2.
Remove the power cord from the outlet.
Inspect the 3 small pins on the XLR (ROUND connector) to the scooter.
Make sure the 3 pins are not damage.
Open the metal 3 pins connector by sliding it back on the cord.
Check for loose connection on the solder tabs.
There should be total of 3 solid solder connections these tabs.
Close up the connector.
Check the connect on the scooter end.
The 3 pins must be clean and able to make the connection.
Please post more information and result on reply.
Posted on Sep 05, 2011
Why won't my Pride Go-Go Elite Traveller batteries charge using a trickle charger? The batteries are new, but my charger quit working.
Hi Robert , can you clarify what you mean by a trickle charger ?, any chance of a photo of the charger ?
using a standard gel battery charger , the charger will charge the batteries in question and once fully charged, the charger will trickle charge the batteries.. This is a standard operation and recommended by battery makers...
Regards
Rob
Jan 09, 2016 | Pride Health & Beauty
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Charger not working fan not stay on and yellow light
You have the 4-amp charger version. If you have the U1 batteries on your Pride you can replace the charger with a 3-amp version after you have your batteries load tested and tested for internal resistance. Verify batteries are good and "finishing voltage" after charging is proper. (14.4volts per battery)
Nov 09, 2013 | Pride Health & Beauty
The Battery does not seem to charge so I want to remove it and see if it will charge if connected to an external charger. How do I remove the said batteries?
Remove the batteries .. Every Chair is different .. but if the batteries aren't charging it's probably that they were left uncharged for a time and they dropped down enough that the charger dosn't recognize them .. If they drop down below around 6 volts the charger won't charge them ... I have taken batteries out and charged them individualy with a car charger .. but they never come back .. at best half life.
Aug 31, 2011 | Pride Mobility Products New Pride Mobility...
Batteries won't fully charge
Jun 27, 2010 | Pride Line Rally Scooter 3 Wheel Viper
Where can I buy a battery charger for my Jet 3 model #2904-24. My batteries will not charge up anymore. Bateries about 2 years old. Email address is horton-cathy@hotmail.com\r\n Thank you James Horton
Hi. Try a google search for your nearest pride dealer.
You would be better advised to get your batteries tested first. It is more likely to be a battery fault.
If you do need a new charger, ask for one of the new pride chargers, as are sold with the Pathrider 130 XL mobility scooter. These chargers are a very good charger. Once the batteries have been fully charged, the charger drops its charge rate to 27.6 volts. This means that you can leave the charger on for days at a time, and not overcharge the batteries.
The older 4 amp chargers maintain the full rate of charge, and do not drop down to the lower charge rate. These chargers should only be used for overnight charging after each use.
Good luck. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
We have a 11 month old elite traveler scooter. The battery will not take a charge. We have had no previous problems. Any suggestions?
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
May 19, 2010 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
160 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
