Question about Toshiba DVR620 DVD Recorder/VCR
New dvd/vcr 620ku recorder won't turn on. green light comes on then off.won't hold power
When on button is pushed, the green light comes on for a second or two then goes off and stays in a stby mode (dashes across small screen) so can't get the unit to turn on mode. dvd disc door won't open and can't insert a vcr tape either. Is there something I haven't thought of to do. I've made sure all the connections are as instructed using s-video. The remote control does not work either, Batteries check OK.
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: A DVD got stuck in the dvd player
unplug dvd player, hold down open button, then while continuing to hold down open button, plug dvd player back in.
Posted on Mar 16, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
SOURCE: Toshiba Hdd/Dvd video recorder. Moved unit
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Posted on Jun 04, 2009
SOURCE: toshiba D VR660KU DVD VCR combo
The unit will only allow 2 hour recording on the DVD+R format. The DVD-R format is adjustable for longer recording time, just understand that the longer recording times = the lower the quality of the recording.
Posted on Jul 07, 2009
What is difference between 620 and 620ku?
The 'ku' may designate in which (world) region it is to be used.
Jun 04, 2015 | Toshiba DVR620 DVD Recorder/VCR
My tv won't come on the green power light just flashes?
push and hold the power button, i did yhat to mine and it now works,also if it comes on reset the tv
Dec 12, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
I have dish network need code to record to vcr . three diget code. wv206a
You may want to try a method called a Power Scan to program this. The steps are included below:
Power Scan DVD VCR:
1.) Press and hold the correct VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 500 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button
If this doesn't work repeat steps 3-6 if the lights at the top of the remote blink rapidly then you have tried all codes possible.
Daniel Busa
DISH Network
Customer Service
Apr 23, 2011 | Funai TruTech DVDVCR Dual Recorder
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
I just got a new Dish VIP 211K system. I am having trouble programming the Dish remote to control my Sony DVD-R/VCR combo system. None of the codes in the book are working with it. I need to program it...
Hello, Cheri Torres with DISH Network Customer Service here.I came across your post and wanted to see if I could help. We have a fewdifferent codes for each of our different models of remotes. I will list herefor you the best codes for the more popular models of remotes and also theinstructions for addressing the remote to the TV. The best codes for the SonyDVD/VCR are 817, 778, 818, 768,005 and 002. I hope you find these codes andinstructions useful but if you do not I will also list here for you theinstructions for running a power scan which can sometimes find the code foryou. If you have any other questions or concerns feel free to email me atCheri.Torres@Dishnetwork.com. :)
Instructions for addressing your remote to your DVD/VCR
  1. Press and hold the desired Mode button until all mode button backlights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
    • Press 0 for a TV
    • Press 1 for a VCR/DVD
    • Press 2 for any other device.
  3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
  4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
  2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
    • Press 0 for a TV
    Then Press STAR (*)
  3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
Feb 09, 2011 | DISH Network ViP 211 DTV Receiver
50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Feb 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Toshiba DVR620 DVD Recorder/VCR Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
