Question about SanDisk Sansa e250 MP3 Player
Removing pictures i have a ton of pictures taking up space on you MP3(sansa e250 2.oGB) and i can't get any of them off. Does anyone know how?
    Problem Solver:
  • 4 Answers
I also had this problem. I worked it out by going into "My Computer" then clicking on the Sansa e250r folder, and then there should be four folders that say "Pictures", "Video", "Data", and "TMP" or something like that. To remove things I would go into the Picture and Video folders and have to do the old fashioned right-click delete. *by the way, I might be wrong but you might also have to right click on the Sansa folder and click "view as folder" or something along those lines.
Posted on Jul 02, 2007
SOURCE:
My sansa m250 says it's almost full, but it's not!
This is hard to explain but you do have files on your player.. It is like having 2 players in one, or 2 different memories, check out this tip posted here...Solve your MP3 Player Connection Problem.
Jun 10, 2010 | SanDisk Sansa m250 MP3 Player
My sansa fuze 4 says not enough room for music db please free 90mb what does that mean
There needs to be some space for the part that finds and tracks the songs. There are too many songs/pictures/video on your Sansa. Remove some. Its always good to have some extra space. Don't fill it up completely. Always leave 100megs free when loading the player.
Mar 21, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze deleted itself
slide the power switch to hold and then connect to system,....it must be detected as a removable disk....then format the player....that should fix the issue...if it doesn't you will need to reinstall the firmware....install sansa updater from the disk provided alongwith and use it to repir your player by updating its firmware...
Aug 22, 2009 | SanDisk Sansa Fuze MP3 Player
Dont know how to put pictures in my mp3
To transfer photos and video to your Sansa e250:
1. Open Sansa Media Converter on your PC
2. Connect Sansa e250 to the computer.
The detected Sansa e250 will list the available space and total space on the
device. If more than one device is inserted, only the first device will be
supported.
3. Add the media files to be converted
4. The Sansa Media Converter will place all files in MyAlbum unless you
type in a new Album Name at the bottom of the screen. Use this option
to organize your files and slide shows.
5. Press to start the conversion process. A status box will appear
showing which file(s) are being converted.
6. Photos and Video can not be transferred to the microSD card.
7. Do not move your photo or video files from the location the Sansa
Media Converter places them.
8. See Safely removing your Sansa from the Computer instructions
below.
Also you can take a look at the manual on page 16..it will give you a visual Image..
http://www.woot.com/files/sansae200manual.pdf
If you need further assistance you can contact sandisk or myself
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 31, 2008 | SanDisk Sansa e250 MP3 Player
Unreadable files for Sansa e250
Don't worry, there's a solution.
You have to run what's called "Check Disk."
  1. Switch the sansa player into MSC usb mode in the settings under "USB Settings".
  2. Then plug it into your PC and goto my computer.
  3. Then Right click the player's icon and goto properties
  4. Then there should be tabs on the top of the box that pops up. Click "tools"
  5. Then there is an area that says area-checking with a button that says "Check Now..."
  6. A box pops up; Click both option boxes and press start.
  7. Then exit out of all the boxes and safely remove the player.
  8. Unplug player and let it restart.
WARNING: Sometimes it will make files "disappear", but still use space. In that case you will have to format it and put the music back on. It all depends on how "corrupted" the files were. If your files disappear, reply stating so and I will help you out with that if you don't know how to format.
Thank you and please respond with any comments or more questions.
-John-
Feb 28, 2008 | SanDisk Sansa e250 MP3 Player
Cant load pics to mp3
Did you download the pictures with the Sansa Media Converter? If not they wont be shown in the Mp3 Player.
Feb 23, 2008 | SanDisk Sansa e250 MP3 Player
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
Video problems on sansa
how did you download a video just wondering !?
Nov 06, 2007 | SanDisk Sansa e260 MP3 Player
Used memory i never used
With most MP3 players, some of the memory is used for system files and software. Just delete all the things you done use (i.e. pictures, playlists, Rhapsody Channels) and whatever space you have free is what you have to work with.
If you want more memory, I highly suggest a microSD card
Aug 12, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa m240
Most of the specifications for WMA is based on 64 KPS sample rate and average 4 minutes per song. This is purely marketing garbage as I don't know of many people who listen to 64kps MP3s or WMA's. WMA's you download from Napster, rip from CD, or get from a subscription services are typically 192 KPS which is three times as large. Lowering your sample rate can make your music files smaller, but at a loss of audio quality. The lower the sample rate, the more compression fragments you will have. So it's a trade off between quality vs. quantity.
Aug 15, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
