Question about Lexmark T644 Laser Printer
What does "flushing buffer" mean
The printer will not print. Printer screen says, "Flushing Buffer".
  • Anonymous Apr 23, 2009
    intermediate problems, flushing buffer, printer cycles but nothing prints then it goes back to flushing buffer. Lexmark T644
  • Don  Farrell
    Don Farrell May 11, 2010
    Incoming print data is in buffers while swath memory builds the next sets of image to be put on the page.
    "Flushing Buffer" is the message that appears when an error occurs that causes the printer to dump the contents of the incoming buffers.
    Are you using Postscript or one of the PCL Emulations? What communication port on the printer are you using. If you are using? If you are using a parallel port connection, which parallel protocol are you using?
    Don
    Genius:
  • 1,018 Answers
No response from the original poster as of 6/6/09. Normally, a "Flushing Buffer" message is pointing at a Postscript problem. A quick easy test would be to set the printer for PCL and retry the job. If it works, then you really need to look at the PS print file to find the error. Don
Posted on Jun 06, 2009
  • Don  Farrell
    Don Farrell Jun 11, 2009
    Follow up, clarification:
    A "Flushing Buffer" message is generated by the Postscript Interpreter because the printer is set to Postscript but the incoming data is not Postscript.
    Most likely cause is the the "Auto Smartswitch" on the printer has been turned off.
    Don
    New Friend:
Open paper tray 1 (if it is the default paper tray), take out all the paper, adjust (temporarily) the paper size from letter to a different size, place it back to letter size, place back the paper, place back paper tray 1. Check the correct paper size is configured for the paper tray 1 at the Paper Menu.
Posted on Sep 24, 2013
  • Ulises Fierro Ruvalcaba
    This answer is way off
  • isdia rivero
    isdia rivero Nov 10, 2014
    I believe this is the troubleshoot for a totally different issue, LoL
The first 6 copies print quickly, then it goess to "slow motion" for rest of print job. How can I get the printer to print at the same speed
My guess would be that the quick printing at first is because the print job get spooled into a buffer and when the buffer is full the print job starts. The printer begins printing and using the buffer data as the computer continues to process the job and supply the buffer. At some point the buffer gets empty and the printer is waiting on the computer for more data, causing the slowdown. This rarely happens anymore, unless you have a very old printer or very old computer, as most printers have a rather large internal buffer memory. You may be experiencing issues with connectivity if the printer is being used wirelessly. Check to ensure that the wireless signal is strong to ensure maximum data throughput capability.
Oct 14, 2016 | Office Equipment & Supplies
Printer prints gibberish / screen says flushing buffer after I added this printer to an old dell desktop computer in classroom
Likely there were stale print jobs saved on the comptuer that were pointing to the port you connected the dell to. Or you may have a defective cable to corrupted driver.
Sep 12, 2015 | Dell 5210n Laser Printer
I've got a Lexmark T520 and it's not printing anything from photoshop - it says 'flushing buffer' and then just doesn't print. It will print from other sources i.e. web pages...
to large a data being sent for memory on printer photoshop will be hungry data and its has to small a memory to cope ok for normal printing but not this type of work
Aug 14, 2011 | Lexmark T644 Laser Printer
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
Lexmark E 250 dn printer. Keeps turning off. Switching from blue bulb indicator to exclamation point indiator. Difficult to turn back on by pressing blue arrow button
The problem could be several things, the first one could be a Flushing buffer error. That means that the printer did not understand the print job sent to it and has to be reset in order to continue printing. Second could be a memory full error where the print job sent to the printer is too big and the printer memory is not enough. The third could be the printer front door is not closing properly, make sure the toner cartridge is installed correctly and that the front door is closed. That's all I can think of right now.
Jan 12, 2010 | Lexmark E250dn Laser Printer
I have been printing chapters in a book. One chapter will not print. The message on the Lexmark screen is "flushing buffer". does anyone know what this means or why it will not print?
The 'flushing buffer' is most likely due to a corrupt file or file to large for the printer memory. You can check the file size and reduce it. Also you might want to upgrade your memory for the printer. Also might want to check your printer settings if the page you are having trouble printing is different from the other pages printed, such as text & graphics, etc. There is also a possibly of print program incompatibility or Windows OS Patch required but I doubt this since you have printed other pages without any problem. If you need to re-install Lexmark driver: http://downloads.lexmark.com/perl/downloads/downloads.cgi Or, if you need the Lexmark user's guide & reference guide: http://www.lexmark.com/publications/eng/optras/index.html
May 17, 2009 | Lexmark Optra S 1255 Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
WHEN I HIT PRINT NOTHING COME OUT BUT WHEN I SHUT DOWN THEN I START IT UP AGAIN THE PRINT COME OUT WHY
check and make sure the printer is "online" - look under the printers and scanners applet
Make sure spooling is active
This sounds like the print buffer is not active so the print job is being written to your hard drive instaed of the printer buffer.
Send the document to the printer then double click on the print manager icon in the status area of the screen ( bottom right hand corner) you should see the document in the list and if there is a problem, scroll along to the right to read what is happening with the document.
If this list is full, cancel all documents and clear this list.
Then reboot your machine to clear the printer buffer and the printer should not print anything on reboot.
Then print the document again but only once, then recheck print managers list.
Most printing issues can be seen here in print manager..
let me know if this helps
Swoop611
Oct 29, 2008 | Lexmark Office Equipment & Supplies
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Lexmark T644 Laser Printer Logo
15,317 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
