Question about Samsung HWE450 Wireless AirTrack Sound Bar
How do I get my tv remote to adjust the volume on the soundbar
Is it easy to set up soundbar up to an x box 1? I'm just gunna settle for the soundbar to be used when gaming or using DVDs ect throu the x box.
Connecting your xbox one console to a sound system. this setting allows you to adjust how much the volume change on your tv using the volume up or down.
Jan 04, 2018 | JVC Televison & Video
Pyle #PSBV200 soundbar there's no optical in on back of soundbar,my tv on back of it, does'nt have audio out, to plug in red&white cables, what do i do?
Check if you have coax output (orange colour socket) on TV and soundbar if you have you can link them together for digital audio, if not check if you have a headpone socket if so you can buy an adpter from headpones to phono connectors (your red & white) but be aware that when you turn the volume up via TV remote control it will turn up the volume on the soundbar.
Jun 27, 2017 | Pyle Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
How do I hook up a home theater system to my tv
The following instruction depends entirely on the design of your TV and soundbar. Soundbars are a device that considerably newer than TV technology and thus are not subject to the variety of build standards to most modern TVs; but are usually compatible.
Turn off your TV.
If your TV has an audio out, or variable out, connect 2 RCA jacks to the left and right channels from the TV to the left and right inputs on the soundbar. If the soundbar is "active" thus having it's own amplifier source; turn it on.
Turn on the TV and increase volume. The soundbar very likely has it's own volume control. Adjust volume on it.
Dec 14, 2014 | Televison & Video
Nexus NX5503L120 is the TV I have and I have a Panasonic Soundbar. I want to be able to control the volume from the TV remote.
You may be able to go back to the initial TV set up procedure and select the option of turning off the internal speakers
Dec 17, 2013 | Nexus Televison & Video
Program directv remote to Maxell soundbar
Hi, you will need to access the operating manual for your directv remote. It will have codes in the remote. but most likely it will not work your soundbar as most Directv remotes do not have codes for them, and do not support them. You are stuck using the soundbar remote for your soundbar. The only option you can do is to purchase a learning remote from the store that can program to your directv box and your TV, and you can learn the volume keys to your Maxell sound bar.
Oct 13, 2013 | Maxell 193002 ssb1 soundbar
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Samsung HWE450 Wireless AirTrack Sound Bar Logo
87 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
