Question about Avanti 1.4 cu. ft. Chest Freezer (RF171PSS3910171)
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
Unit is not cooling. May need freon. Cannot find the inlet to add freon in. Need manual for this model 17rg -1.4-serial number 71030309-year-87.
    President:
  • 1,462 Answers
Only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Posted on Jul 04, 2007
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
True freezer
check the condenser and freon
Aug 18, 2008 | True Freezers
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Why is my True THAC-48 unit is not cooling?
need more info. is the condensor fan running? if not thermostat problem.if it is , is the compressor running or just makes a one time click a few seconds after plugged in? (after unplugged five minutes)... if this is the case it probably needs a new start capacitor (170 uf)..if the compressor is running the larger tube going in the commpressor should be cool about 40-50 after a few minutes .. if not then it is low on refrigerant..R-134 after 1995. or R-12 for older models.. now you also have inside fans and thermo buttons that can not be working.
Nov 09, 2013 | True THAC-48 48in Horizontal Air Curtain...
Ice forming on copper pipe coming from compressor
Hi, It is not uncommon for the suction line on a unit to have ice on it when cooling. This means that where the ice starts forming on the line, there is liquid freon there. But, if it continues to get worse, would indicate a problem as you don't want liquid freon to enter the compressor as it will burn out the valves, or slug it as we say. Icing of this line can be from a few things. Low on freon will cause it to ice up. The freezer fan/evaporator fan motor not working. The freezer iced over real bad. An over charged system will do this, but you haven't had to charge it. Check the fan I mentioned and keep an eye on this line and monitor the units temperature. If you start to loose your cooling then we need to go from there. I can't prevent it from forming ice unless I was on site to install my service gauges to check the internal condition. Please keep me posted though. If the freezer fan is not running, this would be the problem and would need to be replaced. If you had excess to a volt meter and it wasn't running, you could check power to this motor. Let me know if it is not running and check the temperatures closely.
Good Luck,
Shastalaker7
Mar 09, 2010 | Freezers
4 yr. old side by side not cooling on either side. Fan running but compresser is very hot.Could it be low on freon? Thanks Tim
They NEVER go low on freon unless you have a leak. If so it must be found and repaired. I would recommend calling a qualified technican to service your unit.
Oct 04, 2009 | Whirlpool Freezers
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
Apr 29, 2009 | Frigidaire Freezers
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
Feb 01, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
My freezer
Be sure your cords in the back are plugged in, and you shut the door completely, if you move the freezer to check if it's plugged in, don't pass out when you see all the lint!
Nov 29, 2007 | Freezers
Avanti 1.4 cu. ft. Chest Freezer (RF171PSS3910171) Logo
200 people viewed this question
Top Avanti Freezers Experts
tom wright
tom wright
Dennis Boxerman
AJMAL KHAN
Are you an Avanti Freezer Expert? Answer questions, earn points and help others
