Kodak Carousel 700 doesn't advance - Office Equipment & Supplies
  • 33 Answers
SOURCE: kodak carousel 650 slide projector won't advance
lmr18, if you are still looking for a source of parts, it would depend on where you are. If in the US, Google Fargo Enterprises Kodak. If in Canada, Doug banks Photo or email me at bytebackkw@yahoo.ca
Posted on Feb 20, 2009
projdoc
  • 2237 Answers
SOURCE: My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
Posted on Nov 13, 2009
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: Kodak 750h Projector - The
If the projector fails to change slides in forward or reverse, then chances are that your projector has a broken cycle solenoid link. The link connects the slide change (cycle) solenoid to the slide change mechanism. Over time the link (made of plastic) gets brittle and cracks. The good news is parts are still available ( www.micro-tools.com) The bad news is this is a difficult repair and usually requires a service manual and a factory-trained repair dealer. Good Luck!!
Posted on Jan 30, 2011
  • 412 Answers
SOURCE: my kodak carousel 5600 slide
You are experiencing a fairly common problem called continuous cycling. It is caused by use or mis-adjustment.
If you feel comfortable with a electro-mechanical adjustment, take a look at the attached picture for the correct alignment of the cycle contacts. The positioning is critical for correct operation.
Turn the projector upside down (unplugged), and remove the bottom screws. Then carefully remove the bottom cover. The cycle contact assembly will be in the center of the projector.
If you need help, contact a authorized repair dealer. Good Luck!!
Posted on Aug 08, 2011
Buttons will not advance carousel
Hardrocko is correct with his analysis. I have attached an image from one of my Service Manuals that may assist you when performing the repair. Good Luck !! Jim
Dec 02, 2013 | Kodak Carousel 4400 Slide Projector
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Kodak carousel makes a buzzing sound and will not advance
Your problem is most likely related to cycle contact adjustment. See the attached illustration for the parts involved and the SPECIFIC POSITION of the contact parts:
Sep 08, 2012 | Kodak Carousel 4400 Slide Projector
Why doesn't the slides advance?
I can only guess, but it is most likely caused by a worn or mis-adjusted cycle contact. I have attached an illustration to show you the proper orientation of the cycle contact. Good Luck !! Jim7390f9e7-725d-4085-9769-5537112e57b1.jpg
Aug 10, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
How do I properly install the carousel? It's not advancing I think it's not on properly.
It is a while since I have handled one, but as I remember, you have to line up the number 1 slide position with the slot in the projector and then it clips into place with a little pressure.
May 17, 2011 | Kodak Carousel 4600 Slide Projector
We have a Kodak 700. After years of not using it turned it on tonight and there was very loud screeching noise. Is it the fan? Can it be repaired?
The KODAK Carousel 700 was manufactured from approximately 1964 through 1972.
The problem you describe is that the motor is spinning but one of the drive belts are not moving. That requires disassembly & complete service. Look for an Authorized Service Dealer in your area.
Oct 02, 2010 | Kodak Office Equipment & Supplies
Carousel on Kodak 760H races
The kodak 760H needs occasional cleaning and lubrication of the mechanism. The grease gets gummy and sometimes siezes the motor as well. Take to service center to get it cleaned properly .
Hope this helps .
Mar 25, 2010 | Kodak Cameras
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
jasbo
jasbo
