Question about Whirlpool GHW9300 Duet Washer
F 11 error code on Whirlpool Duet - Serial Communication Error ?
My washer sometimes gives an F11 error code-"serial communication error".  It still works, but I'd like to resolve the problem before it breaks completely.  Is this something I can fix? How do I start troubleshooting? what model number are you having these issues with. I have a GHW9300. And how much was the replacement component?
  • Anonymous Apr 20, 2009
    tech said only repair is to replace both units.... over $700!!! What a rip off!!!! Seems like a common problem too... beware!!!
    Scholar:
  • 105 Answers
Your F11 Code is stateing these things but if it is intermittent probabbly a loose connection.
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on Feb 10, 2009
2 Suggested Answers
SOURCE: F 11 error code on Whirlpool Duet - Serial Communication Error ?
I believe EVERY machine will have this F11 error eventually. Here is what fixed mine. Remove the top cover by removing the three 7mm screws on the back of the machine at the top. Slide the cover to the rear and lift off. The CCU board has 2 relays on it. They have white plastic covers. One is labeled K4 and I believe the other is K2. There are five legs on each relay soldering them to the circuit board. Remove the circuit board from the machine. It is the one you can see with the top off in the back of the machine. Unplug all the connectors. Unsolder the 2 relays...brand name Omron. With a jewelers screwdriver carefully remove the plastic cover on the K4 relay. Examine the contact points on the normally open contacts and I will guarantee they will look dull and burnt. They should be bright and shiny. You can burnish the contact points lightly and clean them with electrical contact cleaner. If you take off the cover of the 2nd relay you will see the contact points are nice and bright and shiny. Swap the 2 relays and resolder them on the circuit board. While you have the board out, take a pencil eraser and rub it on the contact points where all the connectors slide onto the board. Spray the electrical contact cleaner to wash any residue away. Carefully reinstall the circuit board and replace the top cover. Our machine has done dozens of loads since I did this with no more problems. I expect another failure at some point when the points deteriorate on the swapped relay. At that point I will try and find replacements for both relays. The K2 relay apparently has less voltage going thru the contacts and does not fail. If you feel real comfortable, you can check the "wiping" action of the points by manually operating the relay when you have it out. I adjusted mine to give a bit more wipe on both relays. I hope this helps...it worked for me!!
Posted on Jan 10, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    We have a Duet that is 2yr 2 month old the washer will not spin and give a F11 code. What do I do?
    HELLO THERE
    F/11 Serial Communication Error
    • Check MCU
    • Check CCU
    • Check Motor
    Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F11 and/or dl code on a whirlpool duet front load washer
    F11 is:
    Check for:
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    Check the above link for a detailed article about the f11 error code.
    Courtesy:JSrock
    Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F11 Code Showing
    F11 is:
    Check for:
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    Courtesy:JSrock
    Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    The F11 error. Where is bottom panel?
    f11 serial communication error.communication between the central control unit {ccu} and the motor control unit {mcu} cannot be sent correctly.
    Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code F11
    Not sure what machine you have?
    F11 Error Code for Whirlpool Duet & Duet HT :
    F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
    Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
    This is the only F11 Error code I could find for a washer.
    Jan 13, 2010 | Dryers
    Whirlpool ghw9150pwo f11 error code
    f11 Serial Communication Error
    * Check Wire Harness connectors to the MCU, the motor, and Central
    Control Unit (CCU)
    * Check the Drive system for any worn or failed components
    * Check MCU
    * Check CCU
    * Check Motor
    Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Older whirlpool duet washer has error F11
    F11 is a serial communication error between the central control unit and the motor control unit.
    Unplug the machine and open the panels.
    Unplug and re-plug all wire connectors from the ccu to the mcu.
    Inspect all wires and harnesses for a bad wire.
    Could be bad components; ccu or mcu or motor
    Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    ERROR F11 (Whirlpool Duet GHW9300)
    Hi there this is as it reads for your fault code F11
    • Check MCU
    • Check CCU
    • Check Motor
    Feb 10, 2009 | Whirlpool GHW9300 Duet Washer
    Washer stops
    globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
    May 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    663 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
